Glad to see MetalCloak in the game...they make great products! Hopefully they put out some flares soon.None that I’m aware of. I just keep hearing from multiple sources they are coming. No ETA though.
you put armor all or an equivalent on an off road tire...lol...bad move....UPDATE: on the flex ramp when fully flexed (driver’s side wheel on the ramp) and wheel turned full lock passenger, there was VERY light rub on the fender liner on the bottom edge. We have an appointment to install new RCV axles and the Broncbuster axle tube this coming Friday, so we are gonna try to adjust the caster during realignment to move the wheel slightly forward. Otherwise, we think the rub is not an issue given it is so little.
We will likely upgrade to the new MetalCloak metal fender liners anyway.
Got it from StickerFab. Our discount code is BIRDDOG05 and affiliate link: https://www.stickerfab.com/?rfsn=66...medium=affiliate&utm_campaign=6626083.dec8326New checklist item for my build is that Raptor grill with the bronze lettering. Did you paint or wrap it?
You might be able to get by without the body lift with the right offset, but it will be tight. I'm considering going to a 0mm offset to add clearance (currently at -12mm)I'm really considering this... going from Ridge Grapplers 37's to 38's just to get load range C's on the truck. I don't have body lift so I may need to add the high clearance liners...
I had them on for around 25k miles. I had them in 34s on my old 4Runner as well and they weren't too bad. With the Bronco being more noise prone and with increased wear, the KM3s were just too loud for me.I like the the BFGs...what made you decide to go with the NITTOs? How many miles did you have on the old tires?
I'm at -8... I'll go fenders before a BL though. It will be tight for sure.You might be able to get by without the body lift with the right offset, but it will be tight. I'm considering going to a 0mm offset to add clearance (currently at -12mm)
I did not, the car wash place did.you put armor all or an equivalent on an off road tire...lol...bad move....
Unfortunately, we were only out there for a week in Mid July. Probably be a couple years before we go back as we are planning on Moab and Rubicon trail for next year trips.Looks good man. I just watched your Mineral Creek video. Are you still out here in CO or did you head back home?
