- Mike
- Sep 24, 2022
- 3
- 16
- 26
- Los Angeles, CA
- 2022 Ford Bronco Black Diamond
- Black Diamond
General wondering - Can you bolt on a BroncBuster Brace to a broken tie rod to provide enough support and connection to gingerly limp off the trail to a place more friendly to towing/repair?
I bought Buster Braces and decided not to use them after going to OffRoadeo and Moab trails given feedback from others on tie rods seeming to hold up with moderate offroading, gentle steering inputs, and only 35's with a small lift (1.5"). I have spare inner tie rods on order. But wondering if I could use the braces in a pinch to bolt some splint support to the steering enough to get off the trail. Having not seen a snapped tie rod in real life, I wasn't sure if (in most cases) the bend of the inner tie rod prior to snapping negate the ability to bolt on the brace or the brace wouldn't provide enough connectivity to allow the steering to operate and turn the wheel. Ex. would the broken tie rod pieces just slide out of the brace or the four bolts in the brace not be strong enough to handle the force of turning the rods together given no support of tie rod connection. Especially since the bent tie rod from the break wouldn't allow for the brace to be tightened completely leaving a gap between the two brace plates.
I know you can use pipe and weld for a field fix (I have no idea how to weld). I also have never changed a tie rod (particularly in the field). So until I can find a YouTube video specific for that on a Bronco, I'm seeking a range of alternatives just in case.
(Please don't respond with a different aftermarket part I should buy, HOSS 3.0, or "just put the braces on from the start", etc. I know the braces help and their are a range of options. I dont want to increase risk of load to steering system and trying to keep as close to stock as possible. I'm fine keeping the weakpoint the inner tie rod and simply wondering if this would be a legitimate field fix solution.)
Thanks in advance.
Thanks in advance.
