Changing Sirius radio station from steering wheel controls?
Chefdrew
Drew Kendall
Pennsylvania
BMW X5
I’m wondering how to just change the radio station on Sirius from the steering wheel. When I do it now it changes the source so it will send me to AM, then FM. I’m sure this is an easy fix. Thanks in advance for the help.
SuperFord
2013 Ford Fusion
Do you have Preset favorite stations saved?
Chefdrew
Chefdrew
Drew Kendall
Pennsylvania
BMW X5
I have favorites in Sirius but I don’t believe presets
TXBoy79
Trevor
Lakewood Ranch, Fl
Ford F150
Tho only way I can change my Sirius stations on my F150 from the steering wheel is my presets. For some reason it doesn’t just change to the next channel.
jm7097
Jack
Mt. Pleasant PA
2018 GMC Sierra Denali, 2018 GMC Acadia
My GMC is the same way. Need to preset stations.
Blitzjb
Joel
Long Island
2021 Ford Bronco OBX
Program all of your favorite Grateful Dead and rock stations. The arrows on the right side of the wheel. Voice controls also work great. I am able to open my car via Siri and voice control
Naters317
Nate
WI
22 Bronco Base Sasquatch
You should also be able to press the voice activation button and just say, "Sirius channel insert channel number here" I'm not sure if saying the channel name works but numbers for sure work
Panzer948
Bryan
Charlotte, NC
1981 CJ5, 2015 BMW M4, 2019 Jeep G.C. Trailhawk
This is true and I was a bit surprised this was the only way as well. With the number of stations now available it seems the automakers are giving us less options/ways to easily change the stations... I still am not use to it as it essentially only gives me about 8 Sirius Channels and 2 Terrestrial Radio channels to scroll thru (recall that you can mix terrestrial and satellite radio stations in the presets).
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Yup, for radio fwd/back buttons, it only toggles your presets...
You get 3 pages of them
3? I only have 2. I’ve been meaning to look up if you can add more…
BrentC
Brent
Calgary, AB
You can add up to 5 or 6 pages, from memory. I did this in my Bronco and 2019 F150. I started noodling around in the settings and found the way to set how many pages you can see.
redone17
Cold Spring, NY
I gotta look into that.
BrentC
Brent
Calgary, AB
Yep, I’m heading out in a bit so I’ll navigate the screens and find the one you’ll need, and post it here. An internet search may also give you the details.
redone17
Cold Spring, NY
BrentC
Brent
Calgary, AB
Yep, the setting is under “SiriusXM” in the “Settings” section. The last line sets the number of pages you can preset.
This is an odd place for this feature to be located because you can use the presets for any radio stations as well.
