Cheap ditch lights installed.
‘21OBX
90Bronco19
2022 bronco outer banks
Ford Bronco Cheap ditch lights installed. 2E13A689-032B-44F7-9DD0-502C2151DF47
I came across these in another thread titled I don’t care if it cheap. Well I decided to give them a go. Even if they don’t last all the wiring and ground work is done for a better set. They are a hybrid of sorts spot and flood. They illuminate out to where I believe I need. I don’t have aux switches so I bought the dual fog light switch from ford and wired the rear fog switch to trigger the relay for these. First pic just the headlights. These also have an amber side that I will hopefully hook up tomorrow undecided if I want to make the amber turn signal drl or just another switch.
Ford Bronco Cheap ditch lights installed. AD699D2E-A8E8-41C7-B6A4-3EF76E13F3D1
with ditch lights
Ford Bronco Cheap ditch lights installed. F7B005DF-8085-4BB7-A33F-31E87671346D
The nice thing is the way it lights up the camera view for the tires.
Ford Bronco Cheap ditch lights installed. FDB3036E-9E1E-4C8D-A904-DC402F28CC54
Ford Bronco Cheap ditch lights installed. BB5302F7-B088-475E-96E6-3A99E7FB04A2
Ford Bronco Cheap ditch lights installed. D42091B8-1E78-4280-B41D-C6A774977D32
Ford Bronco Cheap ditch lights installed. B79F903C-9695-401F-AD53-466D6B94E72D
infound if you run the wire like this the it doesn’t hold the cowl panel up at all.
Ford Bronco Cheap ditch lights installed. DC1201B9-2368-40ED-A9F0-35EC0577693A
Ford Bronco Cheap ditch lights installed. 5828099D-BD3C-43CF-8DE8-1DB2F97C98D1
Ford Bronco Cheap ditch lights installed. 9A62C474-FDDE-4001-A7F0-A67772BDD783
R.A.N.M.J.
Rick
Not too shabby. I bought a set of these to try out for $36 bucks. Mine still haven't arrived yet. Looks like I won't be disappointed.
‘21OBX
‘21OBX
90Bronco19
imabadbadlands
Matthew
Out Banks Squatch
How easy was the install? Did they come with everything needed? Did you hook up to Aux switches?
‘21OBX
‘21OBX
90Bronco19
I don’t have aux switches😢 I bought the headlight switch with front and rear fogs and hooked them to the rear button. Install was like any other light. I did buy a wiring kit with relay for $10 so I wouldn’t overload the circuit.
‘21OBX
‘21OBX
90Bronco19
nice. need good lights to 4wheel around cemeteries too
I live right next to a cemetery best 4000 neighbors I’ve ever had. Quiet never complain lol
imabadbadlands
Matthew
Out Banks Squatch
Dang - im nervous about this now lol
‘21OBX
‘21OBX
90Bronco19
Why that? It’s a light nothing to it.
Burgler2112
Andrew
2022 Black Diamond Bronco 2.3l Mid Soft Top
with ditch lights
did you have to remove the cowl panel to run wiring? Or were you able to slide it through?
‘21OBX
‘21OBX
90Bronco19
I took off the part of the mirror that says accessory ready. And just lifted the edge of the cowl panel.
