- First Name
- Ken
- Joined
- Jan 24, 2022
- Threads
- 101
- Messages
- 2,592
- Reaction score
- 3,340
- Location
- 90Bronco19
- Vehicle(s)
- 2022 bronco outer banks
- Your Bronco Model
- Outer Banks
- Thread starter
- #1
I came across these in another thread titled I don’t care if it cheap. Well I decided to give them a go. Even if they don’t last all the wiring and ground work is done for a better set. They are a hybrid of sorts spot and flood. They illuminate out to where I believe I need. I don’t have aux switches so I bought the dual fog light switch from ford and wired the rear fog switch to trigger the relay for these. First pic just the headlights. These also have an amber side that I will hopefully hook up tomorrow undecided if I want to make the amber turn signal drl or just another switch.
with ditch lights
The nice thing is the way it lights up the camera view for the tires.
infound if you run the wire like this the it doesn’t hold the cowl panel up at all.
