I have a few questions about what I have (may not need to install) and any added things I have not listed.
PNP Kit 12
Audio Control LC.1-800 (500 at 4 ohm)
JL 12w3v3-4
Focal ACX100 (x4)
Focal ACX165 (x2)
4AWG amp install kit for AC amp
Questions I have:
Can I supply both amps with the amp kit w/ splitter or do I need to do a distro block install under the hood?
Do I even need to use the PAC 1.2 LPA from Kit 12 since I'm using the AC amp? AC has options that alot of other amps do not have for signal input, on top of correcting the signal, I believe. (would have to know AC tech to answer this, really)
Bass blockers (and which FQ to use) on the dash speakers?
I'd rather power the dash and kick panels with the key amp and let the radio power the rears (I fade heavy to the front since daughter says the those back speakers are loud since on the 2 door the speakers are right behind your head, literally)? Any "how-to" to accomplish this?
Anything else I may be missing in the design I haven't mentioned is appreciated.
PNP Kit 12
JL 12w3v3-4
Focal ACX100 (x4)
Focal ACX165 (x2)
Questions I have:
