Concerns with using Seasucker rotopax mounts?
5280Bronco
Denver
Just wanted to see if anytime had tried the Seasucker rotopax mounts at all.
https://www.seasucker.com/products/rotopax-tank-holder
I was looking at getting the BadassTents mounting option with one support on each side, but with either solution, youre limited to 3 gallons on each side, so there isn't an obvious benefit to running the one from BAT when it comes to capacity.
https://badasstents.com/product/2021-22-ford-bronco-rotopax-mounting-bracket-plate-kit/
I'm just concerned whether hanging weight off the windows of the already questionably built MIC is the best option, so I figured I would ask for some opinions.
It would just be nice to be able to take them off when not in use as I would be using it only a few times a year where we would want to bring extra fuel with us.
I appreciate everyone's thoughts.
5280Bronco
5280Bronco
Denver
Just buy this and strap it on the spare tire, cheaper and possibly safer
https://www.4wheelparts.com/p/rock-...d-on-plate-ac-tr-102s-1/_/R-FTKV-AC-TR-102S-1
Completely forgot about that option. Thanks for reminding me! I know they say to go up to 2.5 gallons for the mounts in the detail, but hopefully I could run two 3 gallons instead. Since I don't have 35s, that would help keep the weight on the tailgate down. Thoughts?
https://rockslideengineering.com/product/ez-rack-kit/
KABQ
Aaron
Albuquerque, NM
I have the Rock Slide rack and it's solid. I've never had it rotate, but if it does you can lower the pressure in your spare (assuming you have a compressor).
5280Bronco
5280Bronco
Denver
