Dash Cam Wiring - help needed
BattleBornBronco
Jon
Las Vegas
2021 Bronco Badlands
I have a soft top too. How did you pop that off? Do you need the A pillar popped off first?
Don’t remember, just kinda pried around. For the roll bar, I disassembled by taking the bolt out. Pretty sure I just pried around the a pillar though.
BattleBornBronco
Jon
Las Vegas
Oof. Thats just complicating things for no good reason. I highly recommend using fuse taps as your fuse box is right below the steering wheel. Much easier run. I can give you fuse numbers for both aux and constant power if needed.
I only have on constant, what fuses are you using for constant and aux/acc?
Theherofails
Thomas
Phoenix
I believe im using 34 (30A) for a constant and 31 for aux/key on power.
If that doesn't work I'll go snap a photo for ya.
34 was the only constant I could find in the entire fuse box on the Micro2 side. 31 could be almost any of the other fuses that arent spares, but it has the proper spacing to fit both fuse taps comfortably.
Aman
Aman
Northern NJ
Take a look at page five of these install instructions for guidance.
Slacker93
Columbus, Ohio
Ford Expedition
What are the fuse # for those?
Slacker93
Columbus, Ohio
Ford Expedition
Just saw this. Thanks
604Bronco
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Electrical is not my strong suit, even very basic stuff. I’m good with the 12v plug, but I appreciate it!
604Bronco
604Bronco
British Columbia
www.bronco6g.com
Anyone aware of a ”DC 12-24V” to “USB-C” cord that would power a dash camera? I feel like this would be ideal, since I have the power port on the dash. I’d prefer to mount my camera on the dash anyways, in case I need to replace my windshield… one less thing to re-do.
Thanks!
Ford Bronco Dash Cam Wiring - help needed A5733222-124D-4E06-ADC3-BA3C34955366
bravely
Brad
3490 s leonard rd, new palestine in 46163
1973 Mustang
Hey folks,
I'm having some issues, and I know many of you have installed dash cams already.
I've wired everything but seem to be stuck concealing the wires along the top of the windshield, as well as down the A pillar. I also don't want to snap or break anything, hence asking for help haha.
I don't need ideas on other paths to take; I'm already committed to this one lol. I just need help on how to remove the A pillar trim, as well as if I need to remove the headliner slightly, how I do that. In the past, I could just tuck the wire up there very easily; not the same on the Bronco it seems.
Thanks!
watching. Along with the camera wiring, I need to get antenna cable from the back to the front.
