DIY Door storage
Bradley Thornton
Bradley
Hattiesburg MS
18 Sequoia TRD sport, 2021 Badlands Sas, 93 Cobra
Kos
Omaha, NE
2022 Ford Bronco Badlands
My plan was to build a platform that mimicked the tie down points for the on board storage. It’d be flat so it can be hung on the wall when not in use.
SDBRONCO
Patrick
San Diego, CA
2021 Badlands Bronco
Following. I like the having on wheels idea for sure.
Bradley Thornton
Bradley Thornton
Bradley
Hattiesburg MS
To be clear I have only tested this on the doors will be taking my doors off and using in about 3 weeks but haven't used yet.
I did take on add a bag on it and slide it up and see it fit well. 1/2-1in play
All 1in PVC
17-1ft PVC
17-10in insulation
10-tees PVC
14-90s PVC
8-4in PVC (This made the ends about 3/4in bigger than the middle) Just liked the idea of adding a little room on the end ones.
8-2 1/4in insulation
Ford Bronco DIY Door storage IMG_9697
Justin
2022 Bronco
Just came up with this door cart a couple days ago, its been working great! I put a couple things on there the jeep guys didn't think about. The ratchet straps are screwed directly to the top 2x4 (the hook have been removed), so the doors can be held secure without having the metal parts rubbing on the paint. I also cut a grove in the outer 2x4s to hold the rear doors on better. The front doors go on first, paint facing toward the center, then the back doors go on plastic to plastic with the paint facing out.
Ford Bronco DIY Door storage IMG_1050
Ford Bronco DIY Door storage IMG_1051
Ford Bronco DIY Door storage IMG_1052
Ford Bronco DIY Door storage IMG_1053
FlyingScot
Tomball, TX
2022 Wildtrak 4dr
All 1in PVC
17-1ft PVC
17-10in insulation
10-tees PVC
14-90s PVC
Really curious to see how this works out, this is damn close to what I had in mind (plus a harbor freight dolly to make it mobile in the garage)
Bradley Thornton
Bradley Thornton
Bradley
Hattiesburg MS
Well it worked
Also if you turn the doors the correct way you can snap the clips if you have the door bags.
I did the dolly but it only cover the 2 middle doors and would tilt. Will need 2 dollies to keep this from happening
This setup takes up a ton of room it does work but just isn't ideal for me.
I plan to have my doors off all summer so space matters I will be going with the wall mount style to save room.
Will be doing something like this when a cheaper option comes out.
https://www.etsy.com/listing/119191...sh_kRhSsPrNNlaKTP0lQhi0bO_lbAalPpKfAOLhteVx6g
