- #91
When your done,Stay tuned wrapping up this morning.
"Stand back and gaze at your accomplishment!
Further more you now only use 2 of (10762803) connectors and 5 of the other. I still need to do more updates in forscan but everything is working. Only the trailer brakes left to test.Ok, trying to add the towing. 2023 they changed the connector like. MwGriswold posted. The new connector has the Yellow,Geen,Orange,Blue,and Brown wires. The O,Gr,Y, are unpinned on the mating connector the Blue and Brown have wires pinned in the mating connector. They go into the harness that follows the frame rail but couldn’t find where they terminated. The Y,Gr,and O are turn/stop and charge and Br is running lights. I can pin the O,Y,Gr and carry those to the trailer connector but not sure how to connect the Bl, Br without splicing. The other connector has all wires mated on both sides of the connector so not sure where to pick up the Gray (reverse lights) wire.I installed the trailer modul and brake controller and programmed them with Forscan. Everything on that side seems to be ok. Im hoping someone will know where to go from here.
My wife mocks me because I stand and stare. Hey question .. I haven't been able to find the forscan module for the 1st values in your table ICM. I get prompted to update mileage but never see the values to change. Any tips?
I am out and about this weekend, but the reverse lights come from the other connector C105 just next to the one you wired, pin or position 40. It is middle row on one end ( you can take a picture with you phone. The Connector has pin location on the back edge)Ok, trying to add the towing. 2023 they changed the connector like. MwGriswold posted. The new connector has the Yellow,Geen,Orange,Blue,and Brown wires. The O,Gr,Y, are unpinned on the mating connector the Blue and Brown have wires pinned in the mating connector. They go into the harness that follows the frame rail but couldn’t find where they terminated. The Y,Gr,and O are turn/stop and charge and Br is running lights. I can pin the O,Y,Gr and carry those to the trailer connector but not sure how to connect the Bl, Br without splicing. The other connector has all wires mated on both sides of the connector so not sure where to pick up the Gray (reverse lights) wire.I installed the trailer modul and brake controller and programmed them with Forscan. Everything on that side seems to be ok. Im hoping someone will know where to go from here.
This is your backup light.Ok, The C105 Conn has the same wires going in and coming out. I didn't locate pin 40 but the same number of wires going in and out so if pin 40 was empty the feeder wire would not be present. The other (new conn) already has the Blue and Brown wires coming out of it. I pinned the Green, orange, and Yellow wires. to get the blue and Brown wires I would have to splice into the existing wires. I tried to trace the existing BL, Br wires through the harness but could figure out where they went. MWGriswolds connector doesnt have the BL and Br wires coming out in his pics. Here is a pic of my Female connector showing the Bl, Br wires already there. We have a Badlands with Lux so maybe that is part of the issue.
For clearing the code. I wrote all the blocks for the trailer module. (Write all).Update on the installation as described in this thread on my 2023 Badlands:
The physical installation has been complete since last week and everything that I test has been functional. The main issue I have still been chasing is clearing the u2100:00-2f code.
I have finally been able to clear the code while experimenting and restoring asbuilt data. The last restoration of my asbuilt data is when the code has finally cleared. Yay! I wish I had the specific step that actually cleared the module. I will share any data I can so I can contribute. .. Admiring the my work! Thanks again!!
Ah that may be the trick .. I wrote each value as I changed it per others suggestions.For clearing the code. I wrote all the blocks for the trailer module. (Write all).
Then make sure you cycle the (start).
All forscan updates complete no codes. Picking up our trailer on Monday!Ah that may be the trick .. I wrote each value as I changed it per others suggestions.
