Yes, the Blue wire also goes to the Bronco's computer, so you don't want to cut it. You don't need to activate the plug, it's ready to go. The Tow Pro is what gives you the brake signal depending on the G force so you don't need Fore Scan to activate it.I am planning on doing this exact install tonight but with tekonsha harness from p3 controller to factory plug and the curt harness in rear.
Why did you tap into blue wire instead of just cutting it? Does it provide feedback back to the bronco?
Did you need to use forscan to activate the plug? I have power to the P3 but donāt know if I am getting brake signal?
I donāt have forscan yet and was hoping to get this working without it.
