Adding factory towing with OEM parts after purchase
Gabby
Gabriella
Milwaukee
22' Bronco, 16 Tiger 800XCx, 96 Duc 900SS/Sp
When I ordered my Base 2dr back in Jan 2022, there was no option to add an OEM hitch. By the time I picked up my little pony wiring, all was in the accessories catalogue. So I decided to skip this particular mod by @BudgetBronco, use the OEM equipment and have Ford install it.
So I went down to Lake Ford in Milwaukee, WI, where I picked the Bronco up, ordered the parts and made an appointment. They still have my truck, but here's how it's going...
Lake Ford quoted ~2hrs for the wiring based on Ford's "Plug'n'Play" estimates. Turns out it's running closer to 8hrs (Lake Ford holding to the original quote). And I just got off the phone with the service rep manager, who wanted to confirm I wanted the electronic brake control before they tear into the dash to install the switch.
Update:
The total time was approximately 14hrs of work and the switch was placed in the center console but right side up (I think?)
Otherwise a clean install and totally worth it.
I doubt I'll have the truck back before the end of the week, which is fine. They gave me a free loaner until the work is done, and I'd rather they do the work slowly and correctly and not feel rushed.
I'll grab some photos once I get her back.
swooshdave
Portland, Oregon
Mustang
Do you need the brake controller? What are you planning on towing? Can't be that big as the 2 door is so short.
robepa
Paul
West Seattle, WA
www.instagram.com
2022 Bronco, 2006 Tacoma, 2020 4Runner
I'm doing the same, my Bronco is on the train and I am dumb/brave enough to do it on my own.
RoverDude
Maryland
2021 Bronco (First Edition)
8 hours is not unreasonable honestly.
But should not have to open dash ( depends on location you want dial)
Link below for what the OEM should generally take.
https://www.bronco6g.com/diy-factory-tow-package-using-oem-parts-and-forscan/
Gabby
Gabby
Gabriella
Milwaukee
Yeah, 8hrs isn't. I think it will go ~12-16hrs, which 🤷‍♀️
The switch I have is a rocker and they have to pop a option cover off to install, hence the dash removal.
Gabby
Gabby
Gabriella
Milwaukee
It's not always about heavy towing. The 7 pin also includes an aux power line and expanded light control. But even some of the open car haulers have the electric brakes now so 🤷‍♀️
fishinhunter12391
Milwaukee
23 Bronco Black Diamond Sasquatch
What Did this end up costing you? Im near milwaukee myself
Gulftrack
JT
Pensacola
22 Bronco wild trak, 22 Gladiator Rubicon
Just did the same. They quoted me 4 hours and were done in 3.5.
Gabby
Gabby
Gabriella
Milwaukee
I'm still in process. But it'll probably end up between 1500-2k. Mind you I bought some parts retail and let the dealer install them.
