Need help installing a tow package for our Bronco without the tow package
jaboticaba
Carlos
Lynnwood. WA
BMW X3 Chevy Truck
I'm looking for help in installing a tow package for our Bronco without the tow package. How much wiring needs to be done? Can I just buy a wire harness kit?
1970AMCAMX
Robert
Titusville, FL
F150, AMC AMX, DF Goblin
There are like 50 threads on this already, just use search
Sandbergo
Jelani & Dave
Orlando
Rogue
jaboticaba
jaboticaba
Carlos
Lynnwood. WA
BMW X3 Chevy Truck
da_jokker
Jeep Wrangler JKUR
So adding a four pin connector is fairly straightforward. Look at the thread about the Curt Hitch. It plugs right into your tail light but you have to run an additional power wire up to your battery (or I believe some have tapped into a power source behind some trim panels in the cargo area).
If you need a 7 pin, that is a whole different story, and a Pandora's box.
I think here's a link where a guy did a video on installing the four pin
https://www.bronco6g.com/forum/thre...r-aftermarket-hitch-and-wiring-harness.34247/
Kekov721
2019 Jeep Cherokee Trailhawk
Here is the harness:
https://realtruck.com/p/curt-t-connector-wiring-harness/v/ford/bronco/2021/
here is the hitch:
https://realtruck.com/p/curt-class-iii-trailer-hitch/v/ford/bronco/2021/
the hitch took like 10-15min to install, the wiring as long as you have the signature led tail lights is supposed to be plug and play.
The link for the hitch is not showing a class iii hitch. This is the Curt hitch that fits: Item # crt-13493
https://realtruck.com/p/curt-class-iii-trailer-hitch/crt-13493/
