Do I need the tow package?
Adumb
Adam
St. Louis
'21 Area 51 4dr
Skeletor
WV
My Whip
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Like take it to any half decent body shop easy to add?
I wouldn't go to a body shop. Any general mechanic could do it. U-Haul will probably offer them even.
bdub2you
Alexandria, VA
Scott R Nelson
Meridian, ID
I don't plan to ever tow a trailer, but I want to stick a bicycle carrier into the hitch. And a motorcycle carrier. And maybe one of those Harbor Freight cargo carriers. My dealer tells me that they can easily add one, someday, when the Bronco finally shows up.
Wanted33
Down south in Dixie
This is the first vehicle I've ordered with a tow package on it as I've always went with the aftermarket. I just use it for a bike rack. And, wouldn't you know it, it's on constraint. But, I've got so many of the "deadly sins" on mine, waiting on the tow package is the least of my worries. :)
EvlNvrDys
Hunterdon County, NJ
Thanks man!
Don't even go to a mechanic. If all you'll use it for is a bike rack. Do it yourself!
I'm sure aftermarket will have these pretty quickly. Probably starting in the $100-$150 range.
It's literally 4 bolts. Do it yourself and save a couple hundred from having a mechanic do it.
Edit: looking at you @Wanted33 😁. I don't get why you guys spend 600 bucks on this if all you want it for is a bike rack. That seems crazy to me. Now go remove it from your build so I can get it! ;)
Wanted33
Down south in Dixie
Yep, there's nothing to it. I installed one on my Jeep in less than 30 minutes, and they are the same design as the Bronco's.
Adumb
Adam
St. Louis
'21 Area 51 4dr
Done!
