Do 35's fit without rubbing?
Nrodondi
Nick
Pa
VW R32
Hi I’m new around here. Took delivery on a 2022 black diamond non Sasquatch. Can I put 35s on it without any trouble? I bought some methods race wheels & want to put them on soon but need to know if they’ll fit without rubbing.
Dan-O
Dan
Fountain Hills, AZ
2021 Bronco Outer Banks
Take into consideration whatever offset difference there is on new wheels too…
PWillette
Parrie
Maine
What width 35 and what is your Method wheel offset?
Nrodondi
Nick
Pa
VW R32
The rims are 17x8.5 with a 35/6.10” offset. Was gonna get a 35x12.5 nitto trail grappler. I think the trail grappler is also available in an 11.5 wide also.
Area51BS
Ron
Badlands non SAS 4dr 2.3
Why did Ford design a vehicle that needs crash bars removed when you can buy it with OEM 35’s. Makes no sense to remove a safety feature they use on every truck they make if I’m not mistaken.
Mortonm
Canada
2022 Ford Bronco Black Diamond
the crash bars are not installed at the factory for any sasquatch/35" tire Bronco from Ford
EDIT: Ahh I think you are saying they should have designed it to run crash bars with 35s
PWillette
Parrie
Maine
The rims should have an "offset" in millimeters...i.e. your BD stock steelies are +55mm, SAS wheels are +30mm I believe. I'm guessing the 6.10" you reference above is backspace...not sure what offset that equates to? If going w/ 12.5" wide tire you'll want a minimum +30mm offset. The lower the offset the more the wheel will poke out-wards.
Beach_Bum
Ken
St. Augustine, FL
I'd go one step further in why were the crash bars designed with tubular steel. If they were designed such as the high clearance crash bars, then every Bronco would have them included and wouldn't need them removed unless going to 37's or larger.
Ford Bronco Do 35's fit without rubbing? 1704805324107
Beach_Bum
Ken
St. Augustine, FL
I'm presuming the offset is +35mm on the Methods as they offer that and 0mm offset wheels (not counting the Ford Performance Methods).
Nrodondi
Nick
Pa
VW R32
Yes I got the offset that methods recommended for the bronco I think it is 35mm.
PWillette
Parrie
Maine
Nrodondi
Nick
Pa
VW R32
Thanks I can’t wait to get these on. What do you think of trail grapplers? Got any tire recommendations?
