Do rock rails need to be removed to install running boards?
Broncogene
Gene
Three way, Tennessee
2021 Bronco black diamond
Does anyone know if I’ll have to remove my rock rails in order to install running boards. Or can I leave them on?
Kos
Omaha, NE
2022 Ford Bronco Badlands
I believe they require the same mounting points so that would be a no.
  • Like
Reactions: rws
rws
Robert
GA
2015 VW GTI, 2018 Silverado 1500 LT Z71
Ford Bronco Do rock rails need to be removed to install running boards? 7B846413-E677-43E5-9604-E981E765C053
Ford factory steps / running boards mount in the same location as the rock rails. So, it's one or the other if using Ford's products.
You may be able to confirm via the build and price site. It won't let you add both to a build.
Bybotie
Nigel
Edge ST, 2021 Mustang Mach1 HP, 2021 Bronco
There are several companies making a combination rock rail/step that replace the factory rails. I have Zroadz installed. I know RTR also makes them.
Kemoslobe
Philadelphia
Acura TSX
Bybotie
Nigel
