- John
- Sep 4, 2023
- 6
- 36
- 20
- Albuquerque
- 2023 Bronco Badlands Sasquatch, 4 Door, MIC, EG
- Badlands
So I'm in the process of prepping my Badlands winch for install, and I removed the steel cable it came with and was prepared to install the new synthetic rope into the same drum hole with set screw. However, the drum flange has a threaded hole and the new rope came with and built for a metal anchor point to bolt into the flange. Clearly neither the set screw nor the flange could hold the 12k# the winch is rated to, hence why you have to keep multiple wraps on the drum.
Since I'm new to winching on cars, are there any pros and cons on flange vs drum termination of a rope, or are they basically the same for security. For what it's worth, the rope has instructions for both options.
