Eibach Coilovers vs Springs Badlands Non-Sas
BroncoVegas19
B
Las Vegas
Ford Explorer
Im looking to get the Eibach Coilovers for my 23 Badlands (Non Sas) 2.7
But I was just made aware that it might be a better idea to just add the Eibach springs instead and leave Stock shocks.
this will give me the same smooth ride I like but give me the lift I’m looking for.
At the moment I have the stock 33’s tires the Badlands comes with. But plan on adding 35’s down the line.
I’ve read through some of the threads, but can’t get a solid answer on which would be a better option for me.
Can anyone share experience with either option?
pros ?
cons ?
** Daily driver (Las vegas area) with beginner to moderate off-roading trails. No rock crawling.
Frankie945
Frank
Louisville KY
Q50
You would probably totally be happy with just the springs and you would save some money for those 35s. But if you did go with those coilovers you'd have adjustability to raise and lower to get the correct height your looking for after adding bumpers and armor (weight) if you decide to add any of that later down the road.
Just wanted to note I run those springs on a Sasquatch trim and I've installed those coilovers on a local guys Bronco and both are great choices no huge complaints with either of them, they perform very well for their price point.
BroncoVegas19
BroncoVegas19
B
Las Vegas
Ford Explorer
I’m new to the suspension world, so please give me some rope here.
I read that both the badlands and Sas package have the same
Hoss 2.0 (Bilsteins Shocks) but different springs. Which is what gives it the extra
lift/hight that allows the 35’s the Sas package comes with to fit without rubbing.
Taking into account that the crash bars are removed also on Sas.
Also from what I’ve been told, the stock Bilsteins have a reservoir and the Eibach Coilovers don’t 🤷🏻‍♂️
Essentially I like to keep the ride I’ve been experiencing so far but add a lift so that I can add some 35’s 3-6 months from now.
Now I have read also that I don’t need a lift to my Badlands in order to fit some 35’s. But then again it’s cutting it close when it comes to rubbing.
I figure if the Bilsteins are on both the Badlands and Sasquatch package
All I really need is the springs for the extra 1.5-2” lift. ?
Or am I missing something ??
Black Wildtrak Bandit
Houston
2022 Bronco
I had the Eibach coilovers installed on my Wildtrak. All four adjusted to max height for my 37s. I like more rake as I have a lot of gear and a RTT for weekend excursions. I don’t feel any difference in ride quality. Note that I also had a ReadyLIFT UCA installed.
Ford Bronco Eibach Coilovers vs Springs Badlands Non-Sas IMG_4739
Hossamus Prime
Arkansas
www.instagram.com
21 BadSquatch,‘21 ExplorerST , RIP 84 & 90 Broncos
Perfect this is what i was looking for, I am getting mine installed this week and was afraid I'd lose some of the rake.
I am running a +1mm offset. I am expecting to have some rubbing on the fender liner backside where that big plastic piece is underneath when running 37s.
Curious of your experience?
Houston
2022 Bronco
My wheels are 20x10 with a -24 offset. The front fenders were an issue until I removed the useless plastic insert located behind the wheel well. I have Rokblokz XL mud-flaps installed, which allows the liner to be pushed well back … no rubbing at all! I’m running 37x12.50R20 Mickey Thompson EXP Legends.
e34john
john
e10, e30, e34
Nice, that is a great stance. Not going that big with mine but hows the nose dive while braking, that is one thing I want to fix. I probably have the lightest configuration with a base 7mt so it should be better than some of the loaded 4 doors but I still want to stiffen the front up a bit while keeping it comfy daily.
Hdscreens
Will
2dr Bronco Badlands
My badlands is non-sas and I’ll switch between the 33” KO2 with optional wheel from factory for daily to my other set when rock crawling/over landing which is a set of wild track takeoffs with 35” KO2. No modifications yet to suspension, still all factory and haven’t had a single rub moment but yes crash bars come off when I have 35” on. I would like another 1” height and liking this spring only idea rather then the coilovers but either way i did want to upgrade upper control arms and upgrade track bar so spring option leaves funds for the uppers and track bar upgrade.
