Administrator
Administrator
Staff member
Doug
We just caught another 2023 Bronco Warthog prototype, this time running on the F-150 Raptor’s 17-inch Bead Lock-Capable wheels, showing more ties to the classic Raptor formula for the ultimate Ford Performance tuned Bronco.
Bead Lock-Capable Wheels Installed On Latest Prototype
While the prototype’s spare tire is equipped with a standard Raptor-style wheel, the four running wheels all appear to be exact matches for the Bead Lock-Capable wheels that are optional on the F-150 Raptor. It’s the first time we’ve seen this next-level style of off-road wheel installed on a prototype for the Bronco Raptor/Warthog.
Raptor-Spec Fox Live-Valve Shocks Visible In Latest Shots
This latest Raptor-based tie-in can be added to our earlier shots of the Bronco Raptor/Warthog, which revealed evidence of the F-150 Raptor’s trick shocks visible underneath the prototype. Today’s shots give even clearer evidence of the orange-hued Fox Live-Valve shocks soaking up the bumps at on the prototype’s front-end.
The high speed, Raptor-style intent of the new Bronco Warthog was made clear in Ford’s teaser shots of an airborne prototype, and the Raptor influenced suspension spotted on this prototype further nails down its mechanical makeup.
The rear suspension shows signs of camouflage inside the wheel well, but one of our shots shows another bright, metallic orange-colored component peeking through. It’s impossible to see the exact suspension configuration, but it certainly suggests that the Fox Live Valve technology is in use, front and rear.
Ford Bronco Bronco Warthog Prototype Spied On Raptor 17" Bead Lock Wheels Bronco_Warthog_RaptorBeadlock.g01.Bronco_Warthog_6G.com
Ford Bronco Bronco Warthog Prototype Spied On Raptor 17" Bead Lock Wheels Bronco_Warthog_RaptorBeadlock.g02.Bronco_Warthog_6G.com
Ford Bronco Bronco Warthog Prototype Spied On Raptor 17" Bead Lock Wheels Bronco_Warthog_RaptorBeadlock.g03.Bronco_Warthog_6G.com
Ford Bronco Bronco Warthog Prototype Spied On Raptor 17" Bead Lock Wheels Bronco_Warthog_RaptorBeadlock.g04.Bronco_Warthog_6G.com
Ford Bronco Bronco Warthog Prototype Spied On Raptor 17" Bead Lock Wheels Bronco_Warthog_RaptorBeadlock.g06.Bronco_Warthog_6G.com
Ford Bronco Bronco Warthog Prototype Spied On Raptor 17" Bead Lock Wheels Bronco_Warthog_RaptorBeadlock.g07.Bronco_Warthog_6G.com
Ford Bronco Bronco Warthog Prototype Spied On Raptor 17" Bead Lock Wheels Bronco_Warthog_RaptorBeadlock.g08.Bronco_Warthog_6G.com
Ford Bronco Bronco Warthog Prototype Spied On Raptor 17" Bead Lock Wheels Bronco_Warthog_RaptorBeadlock.g09.Bronco_Warthog_6G.com
Ford Bronco Bronco Warthog Prototype Spied On Raptor 17" Bead Lock Wheels Bronco_Warthog_RaptorBeadlock.g10.Bronco_Warthog_6G.com
Ford Bronco Bronco Warthog Prototype Spied On Raptor 17" Bead Lock Wheels Bronco_Warthog_RaptorBeadlock.g11.Bronco_Warthog_6G.com
Ford Bronco Bronco Warthog Prototype Spied On Raptor 17" Bead Lock Wheels Bronco_Warthog_RaptorBeadlock.g12.Bronco_Warthog_6G.com
Ford Bronco Bronco Warthog Prototype Spied On Raptor 17" Bead Lock Wheels Bronco_Warthog_RaptorBeadlock.g13.Bronco_Warthog_6G.com
Ford Bronco Bronco Warthog Prototype Spied On Raptor 17" Bead Lock Wheels Bronco_Warthog_RaptorBeadlock.g14.Bronco_Warthog_6G.com
Ford Bronco Bronco Warthog Prototype Spied On Raptor 17" Bead Lock Wheels Bronco_Warthog_Warthog.z03c.Bronco_Warthog_6G.com
Ford Bronco Bronco Warthog Prototype Spied On Raptor 17" Bead Lock Wheels Bronco_Warthog_Warthog.z14.Bronco_Warthog_6G.com
beachman101
;pkl
I dont really like how wide it is. It actually looks like some sort of clown car.
However its clear from this photo that it has MASSIVE wheel travel. Maybe they are trying to do a production version of the Type R? maybe this is a "super wildtrack" that is strictly for extreme stability high speed off road. Like a trophy truck
also what do you think those "blocks" are hiding on the doors.
pandapaul
Paul
Tallahassee, FL
2021 Badlands Sasquatch
All I can see is a nose poking out over a mask. I die inside every time I see someone doing that.
Edit: I lied. I also see a chonky broncy, and I like it.
BroncBro
2019 Tacoma 4x4
Awesome! Thanks Doug.
We needed something to lift our spirits right now. .........
Ford Bronco Bronco Warthog Prototype Spied On Raptor 17" Bead Lock Wheels FD74F060-36CD-474F-B35E-7616BE5F083F
codydb19
Cody
Silverado
Ford Bronco Bronco Warthog Prototype Spied On Raptor 17" Bead Lock Wheels 1601575889067
But I agree with what others have said, it looks kinda ridiculous, hopefully it won’t just have 2 feet wide flares and that the body will actually end up being wider
But who am I kidding not like it matters, I will never be able to afford one...
ausherpharmd
Alex
Illinois
Hyundai Tucson
Ford Bronco Bronco Warthog Prototype Spied On Raptor 17" Bead Lock Wheels 1601576040165
That's hot. Even covered up.
RyanP
Ryan
Maryland
Mazda CX-9
What top are we looking at n the pics? I hope it's MIC and what we might see on the actual 2021 production run.
SamG
Sam
Detroit Area
sas
hmm it seems to be running around the green field village / PDC area.
If someone has time today they should go exploring over there. Where there is 1 there is often many.
desert_rat
Leslie
Honda CRV
damn she thiccc ?
