(ENDED) 🔥 Exclusive Groupbuy: Bronco Triple LED Fog Light Kit for Steel Bumper
OracleLights
New Orleans, LA
www.oraclelights.com
FORUM-EXCLUSIVE GROUPBUY PRE-ORDER - INFO BELOW!
Designed to work with the Factory Steel “MOD” Bumper on the 2021+ Ford Bronco, this LED fog light kit is a quick and easy way to add functional forward-facing LED lighting to your vehicle. The simple bolt-on installation uses factory bolt locations and provides significant visibility through advanced optics without causing glare which can blind other drivers. Typical installation time is under 30 minutes and can be successfully installed using common hand tools by even the most casual enthusiast. This is a complete kit including 2 assembled steel housings, 6 LED emitters, wiring harness, and all necessary hardware.
Ford Bronco (ENDED) 🔥 Exclusive Groupbuy: Bronco Triple LED Fog Light Kit for Steel Bumper Bronco_Triple_Fog_Light_ORACLE-5890
Part #
5890-001 White
5890-006 Yellow
Features and Benefits:
• High-Powered LED Lighting from 6 Emitters
• Easy Install- No Drilling/ Modifications Required
• Switched Relay Wiring Harnesses Included
• Emitters Feature Blacked-Out Design
• High Quality ⅛” Thick Steel Plate
• Rough Powder Coat Finish
• Mounts using Factory Hardware
• Engineered and Assembled in the USA
• Warranty: 2 Year Warranty
More Information / Sneak Peek Thread
Ford Bronco (ENDED) 🔥 Exclusive Groupbuy: Bronco Triple LED Fog Light Kit for Steel Bumper bronco_fog_light_oracle-sq_1024x1024
DEMO VIDEO:
Ford Bronco (ENDED) 🔥 Exclusive Groupbuy: Bronco Triple LED Fog Light Kit for Steel Bumper 1629491320134
We are offering a 30-day forum-exclusive groupbuy for early adopters of this new innovation! These spots won't last long so grab yours now if you want in! (Please note that this is a pre-order for this product.) It's easy to get in on this:
  • Visit the product page for more information and resources.
  • Add the Triple Fog Light Kit to your cart.
  • Check out using code TRIPLEFOG for 10% off with free USA shipping! (discount applies only to this product: 5890-001/5890-006)
  • Done! Your order will be among the first to ship in April 2022!
GET YOUR SPOT NOW!
Normal Price: $359.95 + Shipping
Group Buy Price: $323.96 and FREE USA Shipping
Please note that the initial estimated ship date is currently April 2022 and is subject to change with notice.
If you would like a combination of white and yellow, you can order White and order the following to swap out one or more of the modules to Yellow: https://www.oraclelights.com/products/oracle-lighting-60mm-15w-fog-beam-led-emitter-module The same discount will apply.
Group buy code active until 3/9. Tentative ship date is April 2022 and is subject to change. Must enter code for group buy discount. Only these lights eligible for discount, not applicable for other products. No additional offers are eligible for this group buy. Free shipping offer is applicable to the continental US only.
Tank
Boone NC
18 F150, 18 4runner, couple of old Datsuns
Ordered, thanks!
Fixajet
Wichita KS
2014 F150 / 2021 EcoSport
I went an dun it, pre-order complete!
Rus-T
Rusty
IL
Ford Bronco Black Diamond
Ordered:)
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
JediMcMuffin
Tommy
2021 Bronco Badlands
NICE!! This is quite competitive with my AliBaba sourced build which ran me about $350, this looks even cleaner then what I was able to pull off, though I was able to do a mix of floods and spots. Starting now I'd probably just order your kit. I think some folks would appreciate a photo of your wiring harness.
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
Sure, its on the page in the link but here you go, it's a standard switched relay harness with Dual Deutsch DTM connectors. If you have factory Aux Switches just run the DTM connectors to the Aux switch and toss the rest.
Ford Bronco (ENDED) 🔥 Exclusive Groupbuy: Bronco Triple LED Fog Light Kit for Steel Bumper wiring_harness
OtisFE
Otis
Alexandria, VA
2022 Bronco OBX
Ordered!
Would appreciate your posting the installation instructions when they are available to give me something new to obsess over.....
