IAG EZ lift for a soft top Bronco is only compatible up to 2022. Anyone find a product that is compatible with 2023?
Appreciate the reply! Looking forward when it’s ready to buy. Any idea on when that will be?We will have an updated strut design available for the 2023 and 2024 models soon. The new soft tops are significantly thicker and stiffer than the previous version and as such the current EZ-Lift system doesn't lift the rear as smoothly. With that said, we have the 2023 version top with the current EZ-Lift system installed and it is still worlds better than not having it at all. You just have to help the top lift up slightly when opening.
Following up again to see when you feel your new version for the 2023 models will be on the market?We will have an updated strut design available for the 2023 and 2024 models soon. The new soft tops are significantly thicker and stiffer than the previous version and as such the current EZ-Lift system doesn't lift the rear as smoothly. With that said, we have the 2023 version top with the current EZ-Lift system installed and it is still worlds better than not having it at all. You just have to help the top lift up slightly when opening.
They will likely be ready around the middle of April!Following up again to see when you feel your new version for the 2023 models will be on the market?
Thank you!They will likely be ready around the middle of April!
Any update on these? I'm ready to order when its available!They will likely be ready around the middle of April!
Same here! Looking forward to it.Any update on these? I'm ready to order when its available!
Thanks!
