EZTrunk hard top lift experience?
Lowcountry Bronco
William
South Carolina Lowcountry
Jwells104
Jwells104
Jameson
Austin, Tx
@Lowcountry Bronco are you easily able to store it though? Doesn’t appear to easily fold or collapse.
Lowcountry Bronco
William
I don't have one, just posted an option that I knew worked with a Bronco. It's sizable though but doesn't appear foldable. Good luck if that's what you need.
Ft. Worth Rob
Rob
Ft. Worth
BMW X7, Bronco OBX
I have the top lift pro (not Venture) and just store it backwards directly in front of my Bronco, top on or off. Since you can drive over the base and the top can sit over top of your hood, it really takes up only a few inches of space the vertical bars take up.
HTXTurk
Matt
Houston
2023 Wildtrak
Jwells104
Jwells104
Jameson
Austin, Tx
Hey, curious what you went with for a lift and if you like whatever you chose?
Thanks
I decided to go with the EZ lift. Overall I am super happy with it. It was easy to put together and made from high quality steel (it’s pretty heavy). Functionally, it’s as advertised and I don’t feel sketchy removing the top or moving it into my garage to rest. I left my top off and on the lift in its lowest setting for a week or so and it was fine.
I love that it folds up nicely and able to easily store it when it’s not in use. It takes up hardly any space at all and is sturdy while folded up as well.
