2 DR Hard Top Lift Measurements
Mikey D
Ormond Beach, FL
www.mikedelninno.com
2005 Ford Explorer
Working on a Triple Leg Nylon Sling for a single point Hoist. End connections on back straps will have 4" Flat Hook hooking into outside lift points, and J hook for front single point (probably use noodle to help secure without slipping). I measured approximate mid points for back straps hooking into lift points and it looks like 36 inches or so for each side. It also looks like 36 inches or so to the front for center J hook.
Does anyone have exact measurements to these points, or better measurements for center points using Triple Leg Nylon Sling?
Not sure what to expect when I lift from center points in back with this set up? Unfortunately, no way to adjust once hooks are sewn in.
Mikey D
Mikey D
Ormond Beach, FL
2005 Ford Explorer
Scraped triple leg idea. Went with simple hoist and lift sling. Works great.
ZipZit
Zip
Las Vegas NV
2020 Escape, 2008 Mazda3
? Possible to help others here? Can you provide pictures of your setup? Many thx.
Mikey D
Mikey D
Ormond Beach, FL
2005 Ford Explorer
Don't have pictures of straps lifting yet but was waiting to post when I did. Here's the simple hoist set up.
Ford Bronco 2 DR Hard Top Lift Measurements 1103221522
Ford Bronco 2 DR Hard Top Lift Measurements 1103221523
Ford Bronco 2 DR Hard Top Lift Measurements 1103221524
Ford Bronco 2 DR Hard Top Lift Measurements 1103221524a
Mikey D
Mikey D
Ormond Beach, FL
2005 Ford Explorer
