Finally Frame Mounted Sliders from LOD OFFROAD!!!
Status
Not open for further replies.
MileHighWT
Denver, CO
2022 Oxford White Bronco Wildtrack
Sig series looks great, but my rock protection concerns aren’t covered. The destroyer is still the best looking option I’ve seen that allows for easy coverage though.
in your opinion @LOD Offroad how do the two compare on trail? I’m assuming the sig series is the toughest option.. do your destroyer series on other platforms withstand real trail abuse, or are they intended to be somewhere between a hardcore slider and a ‘definitely not a slider’ step?
LOD Offroad
LOD Offroad
LOD Offroad
Indiana
lodoffroad.com
Jeep Wrangler JLU, Jeep Gladiator, Bronco
Our Destroyer and Armor Lite sliders are not heavy duty, but they will provide protection and take some abuse. The Signatures are our strongest slider.
kevin.gt
Kevin
Canton, GA
Any realistic timeframe on when Signatures will be available?
Wraithracing
Trey
Grand Junction CO
I don't need a hard core slider as that is not my intended use, but I have to get rid of my OEM running boards. Is there a time frame on when the Destroyers will be available for order?
Mirth
Robert
Watertown
2021 Bronco 2 Door
2dr version and im in those look nice
5280Bronco
Denver
@LOD Offroad Two quick questions. Did you guys get a chance to mount the destroyer series back on the Bronco after they were coated? Also, what is the width of the destroyer sliders from the door sill and also how deep is the step cutout? Great work you guys are doing, keep it up!
LOD Offroad
LOD Offroad
LOD Offroad
Indiana
lodoffroad.com
We havent remounted them yet, we've been busy fitting the Signature series. We are hoping to be done with those today or tomorrow and then get the Destroyers mounted for pictures this week... At least that's the plan.
kevin.gt
Kevin
Canton, GA
Are the $0 sliders on your site a way to pre-order, or simply a way for you to show what’s in the works?
LOD Offroad
LOD Offroad
LOD Offroad
Indiana
lodoffroad.com
Basically in the works. The website pages are built when we get close to release.
bohemund
Tyler
Minnesota
2021 Bronco Badlands Sasquatch
I’m really interested in the signature series. Not sure if I want to drill the frame though…can you give any details on how many stock bolt locations they use per side? How “sturdy” of a step are they without drilling? Sorry if this has been addressed but I’ve heard there is wiring in the frame that might be a concern when drilling. Perhaps this is just rumors. Thanks so much for the info!!
LOD Offroad
LOD Offroad
LOD Offroad
Indiana
lodoffroad.com
All three of our sliders (Armor Lite, Destroyer and Signature) will use the same mounting. We do recommend drilling if you plan to use them for anything more than a step. They are bolt on with several bolt locations and will work fine as bolt on only for a step. However the front mounting area on the frame lacks sufficient bolt locations for use as a slider, so we recommend drilling those at least.
We have not encountered any wiring inside the frame rails, but there are wire harness and brake lines on the outside of the frame. These will not be a problem during installation. We had no issues drilling our frame, just need a drill and a few good drill bits, easy.
kpark_67
Aledo, TX
@LOD Offroad Y'all need to keep discussing the 2 door until you get around to a "yes".
Can you really say you've made frame mounted sliders for the Bronco without including the 2 door? 😜
I have a 2 Door Badlands and the only piece of hardware I still need is frame mounted sliders. Getting prepped for my summer adventures. Any news on the 2 Door?
LOD Offroad
LOD Offroad
LOD Offroad
Indiana
lodoffroad.com
Wish I could tell you we do, but I dont....
LOD Offroad
LOD Offroad
LOD Offroad
Indiana
lodoffroad.com
Finally was able to grab some photos of the finished Destroyers!!! Also got a sneak peak of the Armor Lite Sliders in their raw form and ready for powder coat. Both the Destroyer and the Armor Lites use the same heavy duty steel mounts and these mounts are legit! Much stronger than previous designs.
Ford Bronco Finally Frame Mounted Sliders from LOD OFFROAD!!! 1647635094168
Ford Bronco Finally Frame Mounted Sliders from LOD OFFROAD!!! 1647635127369
Ford Bronco Finally Frame Mounted Sliders from LOD OFFROAD!!! 1647635168903
Ford Bronco Finally Frame Mounted Sliders from LOD OFFROAD!!! 1647635201475
Status
