Finally got some old school safari style roof lights mounted
WuNgUn
Ontario Canada
2 door Squatched
haha!
Good catch - I was too excited to get them mounted and once I was done my girlfriend pointed out the very same thing. She made it out, but I kid you not the space between me hitting the ceiling and not was about 0.25"
Winning is winning... Doesn't matter if it's by a mile or a 1/4"!
4avor8ntfair
Houston, TX
BL-non SAS, 2.3 auto
Not sure I love the position the mount puts them at, but there are not currently many on the market so I’ll take what I can get. Anything to avoid the dreaded led light bars.
KCHilites; about $450
Universale bronco light bar mounts from ZroadZ; $125
I like it a lot, but I’d be paranoid about going into park garages! I’d be curious about a lower-profile mount!
SamG
SamG
Sam
Detroit Area
sas
Thought crossed my mind as well. There is an underground garage in Detroit that I occasionally use - that sasquatch on its own already comes close to the ceiling - not sure how this will go now!
JustJD
J
IL
Toyota FJ Cruiser, AMG C63S(RIP)
I’m digging the old school look of those safari lights(y)
SamG
SamG
Sam
Detroit Area
sas
For anyone who who wants to install roof lights, a few lessons learned.
1. Drilling the hole to access the pre ran wire is easy
2. If your bracket doesn’t have a hole to accommodate… we’ll you’re left with a sloppy look as I currently have. I plan on cleaning it up when it’s not freezing outside
3. In my experience taking the cap off of the sun visor mount SUCKED. Plastic got marred pretty good
4. The retainer for the visor mount is really easy to lose.. and I’ve lost mine. Now I need to Jerry rig something
Ford Bronco Finally got some old school safari style roof lights mounted 4259AA44-018A-426E-93CA-A1A949FE4CBB
Ford Bronco Finally got some old school safari style roof lights mounted 7AE236FA-334F-402F-AD59-FB5A28B4694A
Ford Bronco Finally got some old school safari style roof lights mounted EBB754F6-E8B1-4617-9AC2-961774117CF1
Ford Bronco Finally got some old school safari style roof lights mounted 33AA8275-B530-440E-A55A-995EEE4F3E9B
Ksjrb03
Tx
F250
You need a set of panel removal tools if your going to be modding! Access to the shop manual helps as well, so you know what your dealing with clip wise. Ladder or step stool should be on the shopping list as well. :p
TonySTL
Tony
Belleville, IL
I just ordered the Apollo halogen KC lights and lightbar. Can you tell me if the lights are connected by wiring harnesses, or will splicing be required? I'm planning on wiring the lights to the pre-run wiring near the visor for the aux switch. Thanks!
SamG
SamG
Sam
Detroit Area
sas
they have multiple harnesses - you are going to want to splice into all of them if you use the pre-ran wire as I did.
Each pair of lights for my light bar had a hardness. I had to cut into all of them, wire them all together, create one singular positive and negative cable and then attach that to the pre-ran wire.
MikeStLouis
St. Louis, MO
2022 Bronco
Sam: Thanks a ton for all the info. The more I learn - the less i know……seems like the way of the world.
I keep reading that the pre-installed roof wire is TOO SMALL of gauge to run KC lights. That it is likely going to melt. Any thoughts?
I bought the KCs - but the 50” package. I HATE having wires show (and my wife will kill me 😂) so I hope there is an answer.
SamG
SamG
Sam
Detroit Area
sas
The people saying this likely are not electrical engineers.
source; an electrical engineer purposefully put that wire there for the exact purpose of running a light bar.
  • Like
Reactions: Cat
MikeStLouis
St. Louis, MO
2022 Bronco
HAHA! Yep. That crossed my mind. But they say it is for those skinny LED bars….NOT the big KC bars.
I wish I knew more about all this.
thank!
TonySTL
Tony
Belleville, IL
That was my concern, too. I noticed that the amp draw for all 6 halogens is about 50 amps. I thought the max amperage aux 1 switch could handle was 30 or 35. Is this where the relays on the KC harnesses come into play?
Garemlin
Delaware
Absolutely love this look. A couple of KC Rounds on a bull bar would make it complete.
TonySTL
Tony
Belleville, IL
Hi Sam - I wired all of the KC Apollo lights together (I actually wired the 2 spotlights together to run on a separate aux switch), but wanted to know if you had to increase the size of the wire from the powered aux wire to the KC-provided relays. Thanks!
