baseHello @Tomleo67 You do not need to use Forscan, do you have base or LED tail lights?
Then like Oracle said, there is no Forscan required. I installed them on mine with base tail lamps.base
OK Thanks. I thought I saw someone had said it didn't work.Then like Oracle said, there is no Forscan required. I installed them on mine with base tail lamps.
They may have referred to installing the Amber reverse light (separate part) on the base, you do need to flash for that.OK Thanks. I thought I saw someone had said it didn't work.
can I have the link to the ones that will work for my 22' big bend base 4 door conv.They may have referred to installing the Amber reverse light (separate part) on the base, you do need to flash for that.
Glad we could help, let us know if you have any other questions!
https://www.oraclelights.com/products/bronco-flush-tail-lightscan I have the link to the ones that will work for my 22' big bend base 4 door conv.
