Gilligans_off
Vince
Canada
2022 2 Dr Bronco Badlands Sas/lux
interested
Chrome_Pony
Chrome
The Great Land
Possible to tie these into the existing side light buttons on the higher trims?
48W for both would be ~4 Amps. Might be within that switch circuit's range, might not. Should be simple to use that switch to power a relay that then triggers these. Could get wierd if those side lights are controlled by the BCM in lieu of a fused path. Don't have my Bronco to check, sadly.
Mikey D
Ormond Beach, FL
www.mikedelninno.com
2005 Ford Explorer
On the fence. Not sure I dig the extra bulk on the side mirror vs. independent ditch light.
fitzp
Toronto
Forester XT
Awesome. Look forward to seeing pictures of these installed.
Zombie Salamander
numerous Ford vehicles 1970's to present
Count me in, I find these far more streamlined and cohesive than running typical A-pillar pod lights.
Dudeguy
Dude
Toyota
@JP_Oracle will these illuminate the area around/under the front tires? The diagram makes it seem like that area would not be well lit
Ford Bronco First Look! ORACLE Bronco Side Mirrors w/ Integrated LED Ditch Lights 1668116266182
Bruno
Bruno
Montclair
somehow, i'm guessing that these are legal for 'off-road' use only aka not in traffic
right.... then hard pass. I guess Ill need to mount something lower to use on the street.... Guess I should check the rules around fog-lights aux driving lights
Bruno
Bruno
Montclair
Ditch lights are not meant to be used in traffic or for road driving. Expect to get ticketed of you're seen using them on pavement.
JP_Oracle
JP
Metairie, LA
21 Bronco
These are intended for peripheral illumination at distance & won't really cover below the mirrors or around the wheels.
Rock Lights are the best use case for that. We have several options you can view HERE.
mikeeshim
Los Angeles, CA
MBZ E350, supposed daily driver
Do these fit OVER the current mirrors or are they replacements?
Also, what is the power needed on these?
Lèòn
Jersey
Sign me up for the groupbuy!
