- ORACLE
- Mar 13, 2020
- 19
- 619
- 2,015
- New Orleans, LA
- Website
- oraclelights.com
- Bronco
- Undecided
ORACLE Lighting Oculus™ Bi-LED Projector Headlights for 2021+ Ford Bronco
UPDATE: Now Availble!
VIDEO:
Introducing the all-new Oculus™ Bi-LED Headlamp system for the 2021+ FORD Bronco by ORACLE Lighting. Featuring a unique modular design, easy plug-and-play installation, and advanced LED projection with 5,200 Lumens of high-quality illumination for enhanced driver visibility in all weather conditions. The Oculus headlight is compatible with both the standard and signature Bronco lighting models.
Features:
Precision LED lighting projector for optimum light distribution and beam angle. Installs using original mounting hardware and headlight wiring is Plug & Play into the factory connector without additional relays or harnesses. Halo is available in White or Amber LED and features over 200 bright LEDs for a vivid lighting impact.
Benefits:
These all-new headlamps provide enhanced driver visibility with increased and focused LED light output. This complete headlight replacement features a high-precision sharp cut-off line which reduces glare and prevents blinding oncoming traffic even when installed on lifted Broncos. Package includes tool for easy beam angle adjustability.
Modular Design:
The new modular design allows separate components (turn signal, marker lights, and mounting tabs) to be installed independently. This modular design provides smaller packaging size for lower shipping costs for the end user and prevents possible damage from shipping on these components. The modular design also allows for these individual components to be replaced or upgraded down the road when future options are available.
Reliability:
It is undeniably important to implement proper thermal management tools for high-performance LEDs to operate with reliability in various environments. Oculus utilizes both active and passive cooling methods to sustain low LED temperatures. Remote mounted heat sinks and an internal cooling fan work in conjunction to insure proper temperature control and longevity of the LEDs.
Safety:
Light focus is very important for not only driver safety but others on the road who can potentially have their vision obstructed by glare. This is especially significant on lifted vehicles where the light source is raised and, in a position, to interfere with the field of vision of other drivers. These new Oculus headlights feature a very sharp cut-off line and focus light with precision specifically to avoid such issues.
Product Specifications:
VIDEO:
Features:
Benefits:
Modular Design:
Reliability:
Safety:
Headlight Wattage: 36W Each
Total Lumens: 5200LM
Headlight Color Temp: 5500K (Pure White)
Halo Color: Optional White or Amber LED
Certification: DOT SAE 5839-504 HL VOR 19
Patented Design: USPTO Patent D 877,404
Designed and Developed in the USA
Warranty: 2 Years
