Congrats! Which have you enjoyed the most? I had a BD with SAS and currently have a 23 Everglades, which I am loving! I am liking your mods!I’ve had 2 Big bends, 2 Outer banks, a Badlands, a Wildtrak and this Everglades.
What is the percentage in SoCal that takes their Bronco Raptor off road, and what is your source?It will do squat, but won't be very perceptible . Neither will a large percentage of upgrades folks do...
The use cases many Bronco and Braptor owners subject their rigs to is certainly lamentable. Raptors especially
I recall a quote from a FMC F-150 Raptor Product Manager guy boasting that something like 70% of those owners off road. Here in So Cal that's absolutely not true.
Maybe like Ferrari, FMC should prioritize screened clients for the privilege to purchase? Submit your verified extreme wheeling vids or no Bronco for you ?
In case not clear, my above comment (and number) was from a FMC Product Manager speaking only to F-150 Raptor owners and not just those in SoCal. Again, from my experience, his numbers are total BS. Part of my "evidence" here is multiple friends/acquaintances who have F-150 Raptors and NEVER off road as well as simply sizing up drivers and vehicle conditions out on the roads and parking lots. No, not scientific in the least.What is the percentage in SoCal that takes their Bronco Raptor off road, and what is your source?
+1 for this part number, please.I just did one myself and didn’t realize there was a different trim, would you happen to have the part number handy for it, thanks.
‘With a body-on-frame vehicle, the frame takes up the vast majority of suspension loads, so the body – isolated from that frame via rubber mounts — really doesn’t have to be the most rigid thing. But it can’t be a limp noodle, because the body and frame are a system, and relative motion between a limp-noodle atop a frame that flexes as it travels over harsh terrain is going to not only cause significant issues with noise, vibration, and harshness for the passengers, but it could also negatively affect steering responseWhats the benefit here? I know the additional frame brace helps with towing capacity but what does the roll bar brace do for us?
I've drilled and cut the roll bar off so I know...and it's VERY hard material. give it a try for yourself before you tell people it's so normal or easy. you might be surprised.I think normal, high quality, high speed steel bits would be adequate. The steel is probably high strength but certainly not heat treated to a high hardness.
Read the thread. You're dredging. Likely mistake made and acknowledged prior.I've drilled and cut the roll bar off so I know...and it's VERY hard material. give it a try for yourself before you tell people it's so normal or easy. you might be surprised.
Ya, I believe it's some kind of cobalt steel alloy if I remember correctly. The only way it's very easy to cut will likely be with a plasma cutter.I've drilled and cut the roll bar off so I know...and it's VERY hard material. give it a try for yourself before you tell people it's so normal or easy. you might be surprised.
Boron steel alloy.Ya, I believe it's some kind of cobalt steel alloy if I remember correctly.
Nope, I just have experience actually doing this, you don't...Read the thread. You're dredging. Likely mistake made and acknowledged prior.
Post #108: https://www.bronco6g.com/forum/thre...alled-on-everglades.74887/page-8#post-1947256
Mabett? Perhaps Mabett can come up with something that’ll be perpetually out of stock.
