Forscan changes to activate 25+ trailer module?
EGSquatched
Central Ohio
23 2dr Base Squatch
Have searched and it seems possible to use forscan to activate the trailer tow module on my girlfriends 2025 base bronco but I haven’t found the changes that are needed. Thanks in advance.
Y2KFirehawk
PA
2022 Bronco Wildtrak
This feels like something done via FDRS (licensed Ford software), not FORScan.
Edit: Looks doable.
RoverDude
Maryland
2021 Bronco (First Edition)
See below for 2025 setting.
The TRM is much larger (more lines/ different, it a diffrent firmware module for 2025+)
also The ipc is slightly different
720-03-02 requires (2) changes
These are what I gave EastALHijet, and they confirmed it worked (for them)
as always:
back your own setting beforehand, and use at your own risk
Let me know if you have any issues
Instrument Panel Control Module720-03-02xx4xxx--Trailer Sway0=Disabled4=Enabled
Instrument Panel Control Module720-03-02xxxxx1--additional value for (1) is part of 2025 version for trailer Lighting
Instrument Panel Control Module720-07-01xxxxxCxxxx--Trailer Brake Controller4=TBC DisabledC=TBC Enabled
Body Control Module726-01-02xxx1xxxxxx--Trailer Connect Config0=Disabled1=Enabled
Body Control Module726-40-01xxxxx1xxxx--Trailer Outage Config0=Disabled1=Enabled
Body Control Module726-69-02xxxxxxxxx1--TRM Installed / Config0=Disabled1=Enabled
Parking Aid Module736-01-01xx8xxxxxxx--Pam Config0=No Trailer Module8=Trailer Module
TRM Trailer Module (TRM)791-01-019000000091BB
TRM Trailer Module (TRM)791-01-02070A000000AC
TRM Trailer Module (TRM)791-01-03000006A2
TRM Trailer Module (TRM)791-02-01A301004B4BD5
TRM Trailer Module (TRM)791-02-024B4B4B00007D
TRM Trailer Module (TRM)791-02-0300FA001900B0
TRM Trailer Module (TRM)791-02-040500320005DA
TRM Trailer Module (TRM)791-02-0500000A0003AC
TRM Trailer Module (TRM)791-02-06001E000E07D3
TRM Trailer Module (TRM)791-02-07D00000000071
TRM Trailer Module (TRM)791-02-080000000000A2
TRM Trailer Module (TRM)791-02-09000000A3
TRM Trailer Module (TRM)791-03-01D00064640034
TRM Trailer Module (TRM)791-03-0200009D
TRM Trailer Module (TRM)791-04-01000000FA0097
TRM Trailer Module (TRM)791-04-02FA00FA00FA8C
TRM Trailer Module (TRM)791-04-0300000000009F
TRM Trailer Module (TRM)791-04-04000000A0
TRM Trailer Module (TRM)791-05-0100000000009E
TRM Trailer Module (TRM)791-06-01FFFCFFFCFF94
TRM Trailer Module (TRM)791-06-02F33FFCFFFFCC
TRM Trailer Module (TRM)791-06-03FF007BFF3C56
TRM Trailer Module (TRM)791-06-048022
TRM Trailer Module (TRM)791-07-0103EA051404AA
TRM Trailer Module (TRM)791-07-024B0565010057
TRM Trailer Module (TRM)791-07-030100010001A5
TRM Trailer Module (TRM)791-07-040001000004A8
TRM Trailer Module (TRM)791-07-050005000400AD
TRM Trailer Module (TRM)791-07-065C0075005CD2
TRM Trailer Module (TRM)791-07-0705DC04C30654
TRM Trailer Module (TRM)791-07-088A0000000031
TRM Trailer Module (TRM)791-07-090000A8
Side Object Detection Left7C4-01-01Bxxx--Left BLIS3=Auto / No Trailer
B = Auto /Trailer
7=Manual / No Trailer
F=Manual / Trailer
Side Object Detection Right7C6-01-01Bxxx--Right BLIS3=Auto / No Trailer
B = Auto /Trailer
F=Manual / Trailer
Accessory Protocol Interface Module7D0-01-03xxxxxxx4 xx--Trailer Setup Configuration0=Disabled4=Enabled
Accessory Protocol Interface Module7D0-01-04xxx6xxxxxx--4 Pin/7 Pin Connector2=No Connector6=Connector
Accessory Protocol Interface Module7D0-09-02Cxxxxxxxxx--Trailer Sway4 =DisabledC=Enabled
EGSquatched
EGSquatched
Central Ohio
23 2dr Base Squatch
as always:
B = Auto /Trailer
F=Manual / Trailer
B = Auto /Trailer
F=Manual / Trailer
Wow, much appreciated!! Will report back.
Roundboy
Vermilion, Ohio
2025 Badlands SAS
as always:
B = Auto /Trailer
F=Manual / Trailer
B = Auto /Trailer
F=Manual / Trailer
Well RoverDude, I have been looking for something like this. I will give it a try today. All I got was the running lights working right now. You seem to know your forscan and we appreciate it. If I have anymore problems I will let yo know.
Roundboy
Vermilion, Ohio
2025 Badlands SAS
I got it to work. Thanks for posting the info. I now have all lights working on my 2025 Badlands SAS. Thanks again!
EGSquatched
EGSquatched
Central Ohio
23 2dr Base Squatch
Did you install the tow kit or just the module?
Roundboy
Vermilion, Ohio
2025 Badlands SAS
Sorry for the late reply, very busy today. I installed the receiver, 4/7 pin connector and the trailer module myself. My 2025 Badland SAS had the wire to connect the module to the plug out back. So it was sort of plug and play then programing with Forscan. All in all I think I have a total of around $300 and Ford wanted around $750.
swedemn
Sven
Minnesota
2025 Bronco
as always:
B = Auto /Trailer
F=Manual / Trailer
B = Auto /Trailer
F=Manual / Trailer
Thanks for this. I tried this on my 2025 Base, but ended up with a code that I couldn’t remove. Something about “lost contact with trailer control module”? Sorry, should have written it down. I reverted all changes to saved backups and all is well … except trailer module is still not enabled, of course.
Did I fat-finger something, or is that code expected?
Also, side object detection and parking aid module aren’t available on base, right? So just ignore those?
RoverDude
Maryland
If you don't have a specific module there's nothing to code for those. (Ignore them, because they don't exist for your model configuration)
You have to change a lot of modules. What
module gave you the error?
What specifically was your before and after?
On the trailer control module, ensure that you write all, then reboot module.
swedemn
Sven
Minnesota
2025 Bronco
The error was this: U0137, "Lost Communication with Trailer Brake Control Module".
I installed the kit VS2DZ-15A416-C, does it actually include a brake controller…?
I don’t know which module caused the error, I didn’t check codes until I had done them all. Very possible I messed something up - I’ll try again next week when i have more time.
RoverDude
Maryland
The tow module, trm (trailer relay module)
Fords own description, a referencing the same thing.
The Lost communication could or might be simply when you programmed the module, and it reboots. Because for a few milliseconds it does lose communication if it's system talking to it.
swedemn
Sven
Minnesota
2025 Bronco
Just got back to this. I started from scratch and followed these instructions again, but it still leaves this DTC code that I cannot reset. As indicated, when I start the car the check-engine light does NOT come on (“Malfunction Indicator Lamp is Off for this DTC”). But I’ve tried to reset it and re-read DTS and it’s still there:
Code: U0137 - Lost Communication With Trailer Brake Control Module
Status (-0A):
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Instrument Panel Control Module
Maybe it’s not important…?
TXArea51
Juan
Lumberton
FORD Bronco Big Bend SAS
Just got a 2025 outer banks and I ordered the hitch. After looking I found the trailer light plug, is this plug and play or do I have to do what yall did?
Ford Bronco Forscan changes to activate 25+ trailer module? IMG_9276
Ford Bronco Forscan changes to activate 25+ trailer module? IMG_9277
Ford Bronco Forscan changes to activate 25+ trailer module? IMG_9278
Pedey321
2025 Big Bend w/ Black Diamond Pkg
as always:
B = Auto /Trailer
F=Manual / Trailer
B = Auto /Trailer
F=Manual / Trailer
