Front License Plate Mounting Location
BuzzyBud
TBD
US
TBD
I have one of these ordered, assuming it would work. I however didn't stop to think about the sensors! 🤦🏼‍♂️ It looks like it will still work as there are multiple mounting points on the plate to get it out of the way. Also, I can't quite figure out which package gets the front sensors. I have a BD on order with the mid, and assume it has the front sensors with the co-pilot 360, but I've seen examples of BD with mid without them, soooo 🤷🏼‍♂️ Any one know when the front sensors are added to the modular front bumper?
To the best of my knowledge the front sensors are found on the steel bumper if you select either the High or the Lux packages. When you read the description of the High package, you will see Front Sensor System included.
Thed
Ben
Raleigh, NC
'22 GX460 '16 Miata '67 F-100 '21 Streetfighter V4
Biz
Biz
Canada
21 OBX 2dr / 2019 Edge St / 2016 Focus RS
New guy here from Ontario CA. Same issue front plate required. Best I've seen so far is the shackle mount. I've used sto n sho in the past and have reached out to them to see if they are developing one for the Bronco. I'll post their reply.
https://stonsho.com/
Biz
Biz
Canada
Sto n Sho have confirmed they are making one for the new Bronco. I will post it up when it's ready.
CAD123
Craig
FL Panhandle
2006 Hummer H3
Just me or does the front plate detract from the look?
Lagrange 6g
Tony
Austin , tx
2018 f250 2014 landcruiser 1978 cj5
Are there any photos or ideas of where the front plate will mount to?
And for the people posting, i don't need a front plate, etc. good for you and thanks for the thread bump.
Saw this one on a ob at a dealership in austin yesterday
I think it’s attached to the plastic part of bumper
MattyAg
San Antonio
HBTFD
Newnan GA
F350
deanfromkelowna
Dean
Kelowna
2018 F150, Tesla Model 3
BostonGuy
Boston
Jetta
It looks like all the "shackle" or tow hook mounted plates will only work on the type of hook on the modular front bumper. Has anyone seen one that will work on the standard bumper hook that hangs (d shackle I think it's called)?
Tor148
Tor
Cape May Court House, NJ
23 Braptor Bk, 21 FE RR, 15 F250,
This is what I did.
Its a first edition so has everything, and this is not blocking anything.
Just drilled two holes in the plate to match bolt patteren
Ford Bronco Front License Plate Mounting Location 20210819_202651
Ford Bronco Front License Plate Mounting Location 20210819_202657
Have done plenty of off roading and highway driving and no issues
