Front Locker
Turbo_Lander
Bronco and Raptor
So just noticed (never tried before) that my front lockets won't engage. It's says not available in current 4x4 mode. I tried all 4x4 modes, Rock, Sand, Baja, and Mud. It still says not available. Anyone else having this issue or am missing something? 2022 Badlands Sasquatch
Jason
Jason
2023 Badlands & 2023 Expedition
I am guessing you weren’t in 4L. To test it out, skip the goat modes. Find a loose surface and select 4L. Shift into neutral, and make sure that it engaged. Then, try your lockers. If I recall, the front locker only works under 25 mph.
If you do use goat modes, this chart may help. You’ll still need to shift into Neutral though to get into 4L, which is how you use the front locker.
Ford Bronco Front Locker 1686499261082
Turbo_Lander
Turbo_Lander
Bronco and Raptor
Yes did it in normal mode and all 4x4 goat modes and said not available (in current 4x4 mode) I did shift into 4L making sure I was in N to engage it.
