With the sasquatch flares, the 1mm, the tire tread will be closer to flush with the flares and the sidewall bulge will be past the flare. With the 22mm, the tread will be inside the flares by about .5"-.75", but the side wall bulge will probably be even with the edge of the flare. Here is a pic of my 10" wide -18 wheels with 35x12.50s on my wildtrak sasquatch, based on the numbers, the 1mm would be 1.25" further in and the 22mm would be 2" further in and under the flare. Hope this helps.
