G.O.A.T. Modes
zer0t
Rob
Rumson, NJ
2021 Porsche Taycan 4S
When the truck is running and I turn the G.O.A.T. mode dial nothing happens at all. I wonder if there's something wrong or I'm doing something wrong. Checked the manual and there doesn't seem to be any trick other than the engine running. Thought I'd check here before heading to dealer.
Badlands Sasquatch.
Thanks.
IDyeti
SPAM
Boise, Idaho
21 Bronco BD
Did you try turning it both directions, from normal mode it will only change in one direction not the other.
zer0t
Rob
Rumson, NJ
I think so but I will make sure to try it when I go out later. Thanks.
zer0t
Rob
Rumson, NJ
Nah didn’t matter which way. Once it says drive mode not available.
JBMontclair
Montclair NJ
2021 Bronco - 4 Door - BD - Cyber Orange
Isn’t there a valet mode that can be activated which might limit access to goat modes? Never bothered with it myself . Not fancy enough to use a valet
zer0t
Rob
Rumson, NJ
Well it wasn’t in valet mode, but I put it in valet mode, then disabled valet mode and it worked!
