- Austin
- Sep 27, 2020
- 46
- 996
- 1,567
- Houston, Texas
- 2019 Subaru Crosstrek
- Base
You could just order your own hardware. I use belmetric.com for my old Honda motorcycle project but I'm sure there are standard sized fastener companies. Buy a $2 plastic caliper from Amazon and measure the dimensions and choose an Allen head or even flanged hex head. On average, belmetric grade 10.9 or 8 run 15-25 cents per and you can get a black oxide finish. I chose black oxide for the motor mounting bolts to make the motorcycle frame and bolt blend together and make the silver engine stand out.First, I'm very happy with the all black look. The silver rings just weren't doing it for me. All black much better.
But... The Torx bolts. THEY SUCK. I stripped 3 and they are $10 EACH. That's for a crappy bolt.
And why Torx bolts? They are so easy to strip (before you jump on me I DO have the correct size Torx plus bit) and not very easy to keep the bit on them. They are not very deep.
When I took them off they had some yellow stuff on the threads... I guess some kind of thread locker? Anyway that stuff dried in the wheel threads and it's preventing the bolts from threading in easily. I have to sit and scrape each hole out and then try to put these in without stripping any more.
Are there any kind of aftermarket replacements that don't cost $600 just for a set of bolts that are garbage?
Not a fan of the Torx.
Some antiseize compound would prevent future oxidation and make them easier to remove if you keep the stock ones.
