Deleted member 12854
Guest
The grill should end at the hood fins like the 1971 broncos.
change my mind or tell me an alternative
What is a side safety lightNeeds to be long to mount the side safety light. Otherwise, the cost to mount the front safety light on the body will exceed the total value of the vehicle. That one person to stick it on the front light gets paid 300x more than everyone else because he has to signal by hand. ?
Here is your answer. Give the aftermarket time and this will happen. Thanks to Mo Aoun design.The grill should end at the hood fins like the 1971 broncos.
Thank you, sirHere is your answer. Give the aftermarket time and this will happen. Thanks to Mo Aoun design.
Must fix with aftermarket
Original Light...
thats funny cause your avatar picture is a bronco with a modified grill.all the car designers coming out of the closet
it's a different color LOLthats funny cause your avatar picture is a bronco with a modified grill.
Absolutely. Should be easy and look pretty sweet too.Must fix with aftermarket
