has anyone found an antenna mount for the drivers side A pillar, this spot but a mount for a gmrs antenna?
A template, trial & error, & scrap metal will work until you find what you want.has anyone found an antenna mount for the drivers side A pillar, this spot but a mount for a gmrs antenna?
Couldn't you use the open hole on this picture for the antenna?has anyone found an antenna mount for the drivers side A pillar, this spot but a mount for a gmrs antenna?
No, that's way too big for what I want and I don't need lights up there.Couldn't you use the open hole on this picture for the antenna?
Definitely not! Don't recommend set screws stabbing into the paint.I know it's not on the A pillar. But this is an alternative.
https://www.amazon.com/gp/product/B0842BB2R9/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Well it's a good thing that this mount does not do that lol.Definitely not! Don't recommend set screws stabbing into the paint.
I'm ready to build a mount and noticed the two screws are different sizes, the included kit has one of the bits but not the smaller one, would you happen to know what size bit it is?A template, trial & error, & scrap metal will work until you find what you want.
30 & 25I'm ready to build a mount and noticed the two screws are different sizes, the included kit has one of the bits but not the smaller one, would you happen to know what size bit it is?
I don't own any torx-plus bits so need to order it!
Thanks!
thank you30 & 25
Hi, what mounting bracket is that please? Thanks.
