Help, small stains on brand new paint.
jedmisten
jedmisten
Joseph
CA
Ford Ranger and Ford Flex
Ya, that shit will scratch your paint so I'd be careful with that.
Don't get me wrong - I've used it before on something else on my vehicle and it works great, but apparently it's not good for your paint.
Clay bar or Mr. Clean?
604Bronco
British Columbia
www.bronco6g.com
Mr. Clean Magic Eraser. A quick Google search on "what not to use Magic Eraser on" will have this confirmed many times.
Clay bar is totally fine.
jedmisten
jedmisten
Joseph
CA
Clay bar did not work. 😬
WuNgUn
Ontario Canada
2 door Squatched
R
I have had my Bronco for three days now and I noticed that something hit the doors and it looks like something has stained my cactus gray paint. When I wiped off the debris, it left tiny dots.
I have tried to clean it with soap and water, but the stain seems to be sticking around. Does anyone have any suggestions that would be helpful?
Thanks
Rail dust?
JohnnyBronco
Pennsylania
X4
JohnnyBronco
Pennsylania
X4
Goo Gone
But I always have had excellent results removing tar, paint, etc with a straight polish called Astro Shield. Applied by bare hand, let it dry, you can do whole car not just section by section
Mgro
Matt
NY
4runner
If you clay bar it, make sure you reapply some sort of polish and wax layer. Clay bar will remove everything.
Honestly, unless you know what you’re doing, I’d take it to a professional detail shop and they have the tools and the know how to make it good as new.
jedmisten
jedmisten
Joseph
CA
WarthogJr
Cory
Mesa, AZ
'21 Bronco Black Diamond
Wash with soap and water. Then use 5000 grit wet sandpaper. Then swirl remover. Then wax. This method is safe as long as you don't get too carried away with pressure and time on step two. This takes care of any imperfections in the clear coat, and won't get deep enough to get into the paint. I've done this many times for light surface scratches with excellent results. If your issue is deeper than the clear coat...I'd take it to an expert.
jedmisten
jedmisten
Joseph
CA
Thanks, but I don’t trust myself with something like that. 😬 I am waiting to hear from my service department about a body shop appointment.
