I’m too old to be crawling around in the dirt (unless I have to install tire air up / down system)
RHeinz
Ric
Houston, TX
Headed back out from Houston to Big Bend Ranch State Park next week. I will be trying out “air up”/“air down” system that I built. It’s definitely a copy of what I have seen posted here.
Did the individual tire thing last time. It definitely required a lot of hands and knees in the dirt work.
Hope I’ll be moving up in the world this trip. It inflates/deflates one side of the vehicle at a time. I actually used the Trail Sights to support the gauge and vent valve. Badlands Orange!
Ford Bronco I’m too old to be crawling around in the dirt (unless I have to install tire air up / down system) 2953F899-167D-400D-9CB0-543DD116DD18
Ford Bronco I’m too old to be crawling around in the dirt (unless I have to install tire air up / down system) 0DC6A596-3D2C-4A9A-ACE6-26F12E01034E
After inflation/deflation, it takes a few minutes for the front and rear tire pressures to equalize. Might use bigger hoses next time.
orion
Jeremy
17' F-250, 17' Explorer
Cool. I built my self a 4 way!
Ford Bronco I’m too old to be crawling around in the dirt (unless I have to install tire air up / down system) 20220606_123837
NVCowboy
William
Henderson, NV
2002 F350. 2022 Big Bend (Sasquatch)
Thank you. I’m just now starting to explore inflate / deflate systems and came across the three way manifolds. My first thought was what good does that do? I’ve got four tires. Duh. Now it makes sense.
JScheier
Parker, CO
'22 2dr Wildtrak, '11 BMW M3, '96 Ford Bronco XLT
I use the system from Thor's Lightning. ARB under the hood with a coupler mounted to the modular bumper. Air manifold plugs in there and airs up all tires to the same pressure. 10psi > 36psi in ~10 minutes.
darinhouston
Darin
U.S.
Toyota Rav4
I really like that - do you have a parts list?
RHeinz
RHeinz
Ric
Houston, TX
Sorry, no listing. It was made with a few leftover fittings mounted to a piece of aluminum which hangs on the trail sights. The pressure gauge came from ebay/amazon as well as the valve stem clamps and isolation valves. Hose and various quick connects came from Walmart. The venting valve was leftover from a previous project. Air compressor is Viair
I would be willing to DM you detailed photos if your interested.
darinhouston
Darin
U.S.
Toyota Rav4
Thanks. Sounds like a fun thing to put together. I have bought a few small portable compressor and they overheat too easy. I don’t care how long it takes or how long they last but want something small and inexpensive. Anyone seen any of those retail brands that perform well enough?
darinhouston
Darin
U.S.
Toyota Rav4
I finally built my system - I'm really pleased with my manifold and chuck solution but I've bought three inexpensive compressors now and none of them are great. First one overheated with one tire so I returned it. Bought a cheap dual cylinder with an adjustable pressure shut-off switch and it works fine but is slow (about 14 minutes for all 4 tires from 15-30psi) - tried another (without a shutoff) and it was about 10 minutes. That's not bad, but I confirmed it's not a choke in my 1/4" tubing and fittings because I hooked it up to my garage compressor and it took only 2 minutes for all 4 tires from 15-30psi.
At $39 I can wait 15 minutes to let my tires fill up.
Now I need to find a good bag/box to contain it.
Here's my air system...
Ford Bronco I’m too old to be crawling around in the dirt (unless I have to install tire air up / down system) IMG_5937D.JPG
Ford Bronco I’m too old to be crawling around in the dirt (unless I have to install tire air up / down system) IMG_5938D.JPG
Ford Bronco I’m too old to be crawling around in the dirt (unless I have to install tire air up / down system) IMG_5939D.JPG
j_marinelli
Spring Branch, TX.
