Info for HOSS 3.0 w/ Fox Dampers
Aimless
Dennis
2025 Bronco
I'm trying to find info on these shocks. I'd like to know how these shocks interact with the vehicle.
Can anyone tell me, or point me to a good source, concerning the changes that take place in the shocks when I set different GOAT modes? The reason I ask is I was sitting on an angle, decided to shift into Rock Crawl mode and one corner of the Bronco popped up about an inch. So it appears they adjust immediately to the different GOAT modes, but I'd like to understand what's going on.
Thanks
sag19
'24 Bronco
HOSS 3.0 FOXs are not electronic or adjustable or anything. They can't and don't change with goat modes. Only the FOX HOSS 4.0 on Raptors can change "settings".
You likely had your front sway bar disconnect with rock crawl mode which is what you felt.
alzito
Al
TEXAS
Bronco Raptor, FE, Raptor R, F250
Thanks
Thanks
Shocks do not adjust on HOSS 1,0, 2.0 or 3.0, they do on HOSS4.0(Raptor)
What you are seeing/feeling is the sway bar disconnect that is activated on Badlands or Heritage models in Rock Crawl mode. (Also 2021 First Edition and 2dr 2025 Stroppe)
you can also choose to disconnect in any mode with your far left hero button ont he middke upper dash
