- Brad
- Jun 13, 2022
- 26
- 1,336
- 2,066
- Chandler, AZ
- 2022 Ford Bronco
- Outer Banks
I haven't seen very many posts about this kit (especially with finished photos), so creating my own. Purchased this kit from @4x4TruckLEDs.com . See attached photos and my notes below:
- Diode Dynamics Reverse Light Kit with SS2 Sport pods (flood pattern). Sport light output is plenty. Pro would be too much in my opinion.
- You can pair this kit with SS1, SS2, or SS3. Personal preference on look and light output desired. I felt the SS1s were too small, SS3s were too big, and SS2s were just right (quote Goldilocks & The 3 Bears).
- Very clean looking install.
- Red backlight is very nice and I was surprised by how bright for running lights / back light (these are my first DD lights, so no past experience).
- I also bought yellow/amber covers so I can use these as chase lights. Simple to just pop them on when going off-road. Although I would have expected the covers to clip on better. There is no real defined click when you put them on, and fairly easy to remove them. We'll see how they handle with the bumps of off-roading.
- My setup gets me 3 things......1.) Rear Lights (Red) 2.) Reverse Lights (White) 3.) Chase Lights (Yellow when using yellow covers). The white lights also turn on with your rear zone lighting. Note in my photos my taillight reverse lights aren't on when I'm in white/reverse mode, as I was by myself and had to manually turn them on to take the photos instead of actually being in reverse. I have full control to override the lights since I also have them tied to an AUX switch (main use is for chase lights).
- Install took me most of the day, but I was taking my time and had plenty of troubles. Install video is on DD website under this product. Video is very good. The problems I had were:
Let me know of any questions.
- Stripped plastic trim screws at trim piece concealing taillight adapter (had to drill them out......luckily I had extra on hand).
- Loosening passenger side rear cargo trim panel was a bear. I broke 3 of those white plastic clips as many others have, but already ordered more online. I had to loosen this panel to get to my rear AUX wire so I can manually turn on/off the rear lights when I want to use them as chase lights.
- Tieing into my rear AUX wire was such a small space because I didn't fully remove the panel......just loosened it. And the factory AUX wire is only like 4" long. So having to strip the wire and crimp it was tight quarters. My forearms were fully scraped up from the plastic trim edges afterwards.
- Continuing to tie in the AUX wire under the glove compartment was also a challenge. Not as bad as the rear panel tie-in, but again.....tight quarters and factory wires aren't long.
- This is one of my last AUX switches left, so tying in under the hood was again tight quarters with all my other AUX connections basically in the way.
- If you're like me and have a tailgate table already installed, you need to remove about half of it to get your wiring concealed in the tailgate.
- At the rear spare tire, when you fish the splitter through, the splitter isn't very long. You're somewhat limited to where you can have the wire connectors come out your spare wheel. So if you can, I'd suggest shoving as much of the wire harness through the tailgate out to the spare as possible. It's just tough because you have to get through the air vents on the tailgate and the connectors barely fit through the vents. Definiately make sure you have enough wire through before you re-attach the spare and new bracket, or else you're going to have to remove it all again to fish more wire through (again, depends on your rim openings and how well you can fit your hand through the rim).
