Intercooler Grille Shroud is there a way to remove it?
James Cole
MX
Badlands Sasquatch (hopefully)
Hello guys,
Looking to remove the intercooler grille shroud to possibly increase airflow on a Modular Bumper…
-Is there a how to?
-Will it trigger a CEL?
Thanks!
JC
Bellime
Keith
2022 Ford Bronco
I removed the frame and shutters when I installed the Whipple IC. I removed the shutter motor from the assembly and kept it connected as I wasn’t sure if it would generate an error. One day I will play with to see if the disconnect causes a problem<
Ford Bronco Intercooler Grille Shroud is there a way to remove it? IMG_1627
James Cole
MX
Thanks! Should the bumper be removed to delete the grill… if so is there a how-to for removing the bumper?
da_jokker
Jeep Wrangler JKUR
You must be talking about the active shutters and not the shroud right?
The shroud is just a rectangular plastic/rubber seal that can easily be removed.
The active shutters... That I don't know.
James Cole
MX
Yes I mean the active intercooler shutters I tought it came with the shroud...
I guess it would be bettter to keep the shroud and remove the shutters... the question is how??
THanks!
JC
