Easy to access!
Nows the time to replace the speakers. Your Bronco is speaking to youSo, this just happened. Driving along and I felt something hit my foot and fall behind the clutch pedal. I came to a stop and found the cover to the speaker in the kick panel had broken off and came loose.
Hopefully the rest of the clip isn't stuck up in there and you can have it replaced, it's covered under warranty.One of the clips is broken. I’ve never removed it, so I’m guessing it was broken at the plant and it just vibrated loose today.
Hopefully you won't start hearing a rattle sound when hitting a bumpHopefully the rest of the clip isn't stuck up in there and you can have it replaced, it's covered under warranty.
My thoughts... Get out of my brian!Hopefully you won't start hearing a rattle sound when hitting a bump
Not enough, apparently.Did you wax it?
100 MPH tape fixes everything.100 mile an hour tape will fix that that no problem
That was my thought.It's your Bronco telling you to replace the craptastic speakers
