Something that can be plastic welded or the gap is nessesary?@Cl1ckst3r
Yes that is the part. Hold up to a good light and check for gaps. Mine started with a gap and then within a couple hundred mikes the “cap“ area failed.
K&N has been very easy to work with. Panda has also been responsive.
Man I can't thank you enough. Turns out this was my problem. Didn't notice it being lose and have been driving around with a CEL. Looks like mine straight up blew off.... Reached out to K&N, awaiting a response. Not sure if I should not drive right now or not tho....@Cl1ckst3r
THISS!!! you need a 90 degree pick!! I did the same thing but thankfully my husband was able to drive to the store on his way home and get one for me.First, if you don't want to destroy your factory CCV connector that connects to the valve cover make sure you have a 90 degree pick as part of your tools.
With that said, you can probably guess that I didn't have 90degree pick, so I used a pair of snips to remove this connector....kind of a point of no return decision. This was step 13, so this was the final step in removing the air intake tube.
all this sounds like a pain in the ass , and not worth it to me .
messing with the integrity of the bronco/ warranty
they say it won't mess with warranty issue but if an engine failure were too occur first thing that will happen when it's diagnosed is it will not be covered.
my 2 centavos worth
my 2 centavos worth
