Kicker Key 200.4 Done Correctly
AZCoyote
AZCoyote
Wiley
Phoenix
2024 Big Bend Sasquatch
Great thread.
I have previous experience with a Kicker Key200.4, in a 2022 GMC Canyon (non-Bose) running bi-amp in front with Kicker 2.75 "tweeters" and factory door speakers. I was very impressed with how it sounded. Had a harness made with unterminated wires for the tweeters which I extended as needed.
That said, can I still expect a noticeable improvement if I install a Key200.4 in my 2026 Bronco with B&O? Are you guys and gals installing it under the dash? This would make running new wires easier.
I recently installed Infinity Reference 4" speakers in the dash and was disappointed in how they sounded. I have since removed them while I pursue other affordable upgrades.
Mounted right below the steering wheel on the little panel that is so popular. Works great.
I think there are some B&O specific threads you can check first. Speakers alone usually only help and little.
Pmharris423
Preston
Roswell, GA
Ford Bronco 4Dr Badlands Non-SAS
Round two with DSP. All dip switches are down, except for the 60Hz crossover. I may add compression as I'm still getting clipping at volume 19. Again, 15 is pretty much my highest listening volume but I want to test so it all is working properly.
The systems sounds MUCH better now. The tweeters are balanced, not bright. I also have some 6.5" coaxial speakers in bigger back pods, and moved the fader so they're noticeable but not overpowering. I like.
I read online that lower clipping levels can be normal on the Bronco head unit, and that a Line Output Converter (LOC) between the head unit and the Key 200.4 can help. Maybe later.
My next steps are to figure out the subwoofer and to cut a hole in the protectors behind the Memphis kick speakers so they can move freely.
Pictures for reference:
Would you recommend the 6.5’s in the rear? I’ve been loving the bi amp setup up front but just wondered if a larger full range speaker would give some extra rear fill to the sound.
AZCoyote
AZCoyote
Wiley
Phoenix
In theory you could change the rear pod EQ to full range and those 6.5 may give more volume. But with head unit power I’m not sure it will be hugely different. I personally like just enough from the pods for fill.
Cordycord
Cord
SoCal
2016 Pilot, 2016 E300, 2005 MSM, 2001 B3500, 2010 Range Rover Sport, 2022 Pilot
I gotta say that your advice really drove my build. I installed 90% of it myself, and feel pretty good about it. That said, I've got my system set up with more of a "surround" sound rather than front-bias, and very much prefer it. The dash mid-tweeters hold their own and are very clear in this setup, and the rear 6.5" coaxial Memphis speakers do their very best to mitigate all the road noise and squeaks of the Gen6. This system can't compete with windows down at highway speeds, but is more than enough windows down around town. Windows up and it's a proper, high quality setup.
AZCoyote
AZCoyote
Wiley
Phoenix
That is awesome! It’s DOES feel good to get these things done on your own. Saved money for other mods too!!
I agree about the volume levels. Closed window I have a very high quality and loud soundstage. Windows down at 45 mph I can still jam out. Highway speeds forget about but I don’t really cruise windows down that way.
That’s how I ended up tuning mine as well. Helps to make up for the slap-in-the-face dash window reflection and relatively weak kick panel placement.
I know a lot of people who prefer front facing stereo though. I just found it harder to tune for wirh Bronco acoustics being what they are - but it can be done
