- Banned
Went pretty smoothly.
1. Watch the video by 67BroncoG1 posted in this forum. Note how he ran the plug end from the center console to the glove box. Also note that he unplugged BOTH connectors initially. I didn’t catch that until i got to that point in the install.
2. Some sharp edges under the dash so be prepared for some “skint” knuckles.
3. I removed the glove box and set it in the back seat so I could have room to mount the key.
4. The plastic panels in the bronco are ridiculously cheap and embarrassingly flimsy. The glove box mounting is very cheap.
5. I used the Mountains2metal bracket and it took a hot minute to figure out how it needed to be mounted but it worked great.
6. The auto setup took longer than expected. It seemed like it ended but then it started back again. Just be patient and listen for the happy tones. I used the usb connection.
7. Sound quality was really good but I could crank up the radio volume to 30 with no distortion. Based on comments here, I thought the output would be louder. I did not adjust the gains. I have jl audio c2 in the kick panels and jbl speakers in the dash/rear…
Hope this helps…
Hope this helps…
