Kicker key installed. Notes/observations inside
Gobraphil
Nebraska
  • Thread starter
  • Banned
  • #1
Went pretty smoothly.
1. Watch the video by 67BroncoG1 posted in this forum. Note how he ran the plug end from the center console to the glove box. Also note that he unplugged BOTH connectors initially. I didn’t catch that until i got to that point in the install.
2. Some sharp edges under the dash so be prepared for some “skint” knuckles.
3. I removed the glove box and set it in the back seat so I could have room to mount the key.
4. The plastic panels in the bronco are ridiculously cheap and embarrassingly flimsy. The glove box mounting is very cheap.
5. I used the Mountains2metal bracket and it took a hot minute to figure out how it needed to be mounted but it worked great.
6. The auto setup took longer than expected. It seemed like it ended but then it started back again. Just be patient and listen for the happy tones. I used the usb connection.
7. Sound quality was really good but I could crank up the radio volume to 30 with no distortion. Based on comments here, I thought the output would be louder. I did not adjust the gains. I have jl audio c2 in the kick panels and jbl speakers in the dash/rear…
Hope this helps…
F OR D
BD Green Machine
agree with everything and here are my 2 things:
1. glove box was too much of a pia to run the wires over to. i do like the location, but also wonder about access later, heat, and room/chance of damaging other wiring. column is super easy to access later and i can just cut zips (instead of removing from bracket). only downside is moving the wheel down but i would never have a reason to do that personally.
2. something is off with the setup. on 18 it hurts my ears, and i can't exceed low twenties without risking permanent hearing loss.
Lak34ers
Troy
Seattle
Are you running power off the stereo for the amp or did you purchase the wiring for the plug and play to have it wired to the Bronco battery? I have heard that the battery is needed because it might cut out by just running power off the stereo.
Gobraphil
Gobraphil
Nebraska
  • Thread starter
  • Banned
  • #4
I’m using the plug and play harness.
I’m going to try the gain matching process as shown in this video starting at 9:00
Dmorty217
Derek
Venice FL
Camery
I also have the plug and play harness and cannot turn the stereo above 20 without it hurting my ears.
F OR D
BD Green Machine
PNP to integrate with the stock head unit. Note they have kits for just the Key and numerous sub options.
Added Kicker Key 200.4 to power 4 and 6.5s (also swapped those out)
Put an HS10 in and did run direct power.
Sounds better than high end stock system, limited wiring, and that's great considering I'm working with six speakers and added a sub..
edit: did kit 11-6, it included all wiring for the hs8/10 and key.
ChompSticks
ChompSticks
Cumming, GA
'02 E55 wagon, '98 Suzuki X-90, '96 Town Car
Same here, above 20 and its too loud. Stock speakers and key amp
Dubsesd
Andrew
CT
04 Ford F-150, 06 Roush Mustang
Mines not loud enough and at 18 it cuts out. Power wire is ran from the battery and all my gains are lowest they can go. Not sure what’s going on with it
‘21OBX
90Bronco19
2022 bronco outer banks
Heck above 14 is pushing it for mine to be too loud even on the freeway. 7 around town and maybe 12 ish on the freeway is good. 20 is really jamming! I re ran the setup with the mic on the center armrest and to my ears it sounds better. I have a soft top if that matters.
JediMcMuffin
Tommy
2021 Bronco Badlands
I also made no gain adjustments. I couldn't quite follow their recommendations tho. I do need to dismount the amp from inside the glove box and hit that little button to stop the popping sounds.
Gobraphil
Gobraphil
Nebraska
After a little tinkering, I have no sound on the drivers side. I guess I need to call plug and play…
F OR D
BD Green Machine
try disconnecting and reseating the pnp. make sure you tested each side and f/r. i tested each speaker when replacing and installing.
if everything is tight 100%, probably something off with the kit. they are awesome but slow customer service, i'm sure it will get corrected if that's it. if your ears don't start burning around 20 after a few minutes something is off.
Gobraphil
Gobraphil
Nebraska
I reset the connection and the drivers side sound came back. It really didn’t feel loose but hopefully it will stay seated. Max jamming level for me is about 24 now…
