Leaks from suspension boot?
Benzo520
Ruben
Tucson, AZ
Just noticed a bunch of grease near the front driver side control arm. Must be leaking from the boot right?
bodean
Shawn
Alberta, Canada
76 Mini, 99 4Runner, 07 FJ Cruiser, 16 Tacoma
CV boot, check for any rips or tears. Not uncommon for them to fling excess.
Benzo520
Benzo520
Ruben
Tucson, AZ
I don’t think it would fling this much… just check for tears and saw an excess of grease.
Benzo520
Benzo520
Ruben
Tucson, AZ
I’d clean it and monitor it. Or suck it up and take it to the dealer.
Yea I’ll take it to the dealer tomorrow. Just wanted to make sure this was abnormal first
JohnnyBronco
Pennsylania
X4
If you drove over anything except pavement you may have to suck up the replacement cost. To replace the cv boot should entail pulling that hub off the vehicle which might consume 3-4 hours flat rate. Look at about $500 to fix if not warranty. But if you don't fix it and just keep mopping up the grease, eventually the grease disappears - and then the actual joint with it.
noliveaxle
john
Riverside, Calif
2015 jku rubicon
No non modified new vehicle should do this. This will be cleaned up under warranty and repaired.
wetdog
Bruno
pacific coast
2019 jl
Betcha that boot has a cut in it , grease comes out water goes in cv fails take it in.
Benzo520
Benzo520
Ruben
Tucson, AZ
Took it into the dealership this morning… They ordered a whole new axel for it, and will be replaced under warranty, no questions asked. They’ll contact me when it comes in
1975U15
2019 F-350 SD, 1975 Bronco
Glad it worked out. I'm dealing with similar issue but caught it early. Boot is leaking grease from a tear that I believe occurred on the line during assembly. Taking in this week.
Shamalama86
Canada
2014 FX4 3.5L
This just happened to my 3 day old bronco. Did they keep the bronco or let u drive it whole the part was ordered
Benzo520
Benzo520
Ruben
Tucson, AZ
They let me drive it till the parts came in
Shamalama86
Canada
2014 FX4 3.5L
Oh excellent. So when did you notice ? I just took my stock tires off and was looking around and saw all this grease . 300kms that’s it it lol. And I’m assuming they replaced everything and how long did it take to get the parts and what parts did they replace ? Thanks
