Leaving back window open
Philosophize
F. Sean
TX
21’ Bronco
I do not have someone really to help remove the back top of the Bronco. I can remove the first 3 panels but want to leave the back top on is it fine to drive with the window open or best to leave it the window to avoid drag.
BlazinGTO
Dustin
MA
2004 GTO M6 2004 Escape
I've driven around up to 50ish with the front three panels removed. The back window was down and it was fine.
I haven't tried it but I would like to leave the back window open in the summer. I'm curious if anyone has driven around with it open and did it stay up fine?
Philosophize
Philosophize
F. Sean
TX
21’ Bronco
Like wise
Blackcat
South Carolina
2022 FORD BRONCO BASE 2 DOOR M/T
I wouldn't run at highway speeds with the back window upen, but around town is fine. You don't want to stress the gas shocks that support the back window.
PWillette
Parrie
Maine
It would probably be fine at low speeds but not sure I'd chance running the rear window open...I'm sure it's not designed to run open and it would only take one small rock that clears the windshield to shatter it.
ChrisB351
Shreveport, LA
2022 2dr Bronco, 2005 ZX6r, 1993 Mustang GT
I have a jeep wrangler. Ive done it many times at many speeds. I wouldnt recommend a long trip at 70mph just because, but its not gonna hurt. Anyone who says itll wear out your shocks doesnt realize theyre already compressed when its closed so whats the difference?
Lucky
Jeremiah
Los Angeles
'21 OB Sasquatch V6 2-Door AMB
No one is concerned about the window shattering when it slams shut?
BrentC
Brent
Calgary, AB
I believe behind the spare tire there are already vents that pass air through. I could be wrong but if there is you should be fine to leave the back window down
You are correct. There are relief vents in the tailgate designed to prevent buffeting. The top is also designed to be run with the rear clamshell on the Bronco with the front panels removed.
Best way to prove this - take it up to speed with only the clamshell on and see how it performs.
BTW, there are wind tunnel videos out there showing airflow over open F150 boxes which show how the design of the truck drastically reduces vorticies and buffeting. The flow is smooth over the open box and past the rear of the truck. I’ve proven this many times by having loose items in the box which stay in place at highway speeds. It’s interesting to watch the loose ends of bike tie-downs - they are like sailboat tell-tales and show that the flow is relatively undisturbed.
mds5917
New Jersey
'21 Bronco Badlands, '21 Toyota RAV4 Prime
Honestly, you are driving a brick, so drag is not high on the list of considerations. 😁 Also, the back window barely opens above the MIC top anyway. The gas struts are pretty firm, so it is not going to slam down. Just don't back into anything close enough to crush it...
Destroyer
2002 Chevy SWB NBS, 2022 Bronco
Two examples for you. I regularly run my JK with all 4 doors off, and front panels off the hardtop with the rest still on, going 70-80mph down the highway. Rear glass closed on the hardtop...never had any issues and thats with TONS of more air flowing in with the doors off.
I've also run with the rear glass open around town going 55mph or under...never had any issues. However as others have stated, large bumps that really jar the vehicle I would be worried about as there is really nothing dampening the glass when its up like that.
Philosophize
Philosophize
F. Sean
TX
21’ Bronco
I know right a brick but I wanted the air to flow through.
Philosophize
Philosophize
F. Sean
TX
21’ Bronco
I wanted to make sure I would not damage anything or cause damage to the struts
Oldhippie
Barry
Santa Cruz, Calif.
Of course there is also the exhaust coming into the low pressure area of the cab with the rear open...(it is a minor issue with my model A, no-door panel with open rear)
