As shared above, depends on the foliage and your prep time.While this looks great, I have a total noob question. Do limb risers need to be heavy duty? Bungies, a rope, high test fishing line wouldn't work as long as it's tight? The majority of off-roading I'll do will be through wooded areas in ME, NH, VT so want a solution - just no real world experience as to why a bush fix wouldn't get the job done.
Bungies, fishing line and rope have some give. You can make wire more taught to eliminate any flex/give with the use of turn buckles and accessories. A branch/limb could grab and get tangled and turn into a slingshot-projectile situation. That is just a worst case situation...a bungie/rope trail fix could work just fine.
A Stanley screwdriver usually works just as good as a SnapOn...but there defiantly personal preferences involved!
